Question about Hardware & Accessories
I set home away and sleep for temperatre. I programmed times for station P1 through p4. i verified by scrolling each station. However, the P1 through P4 do not activate. P1 for morning does not ho
I have tried programming it 30 times, thinking I missed a step. Just have hit a wall. We need it to go on and off automatically at same times every day.
  • 1,268 Answers
One step you apparently missed is the one called "SAVE".Try it again and SAVE each time.
Posted on Dec 01, 2014
2 Suggested Answers
  • 5245 Answers
SOURCE: 4 station timer help
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most major brands are linked here, including manuals for each.
Some brands such as yardworks, etc, repackage other brands and have no online support or clear resolution for warranty claim.
Open link, then add a comment with brand and model and voltage so expert can access same manual.
Replace battery. Reset timer. Check if unit is getting power. Check if outlet has correct polarity. Are some basic troubleshoot steps.
Most timers have 1 year limited warranty, and timer that came with used house may no longer be functioning. Or the sprinkler hear has gone bad.
For replacement, I think Intermatic mechanical sprinkler timers are better value than digital timers, since the mechanicals have repair motors and trippers and can last 25 years.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more information on timers.
Posted on May 22, 2013
My stereo keeps turning off when I listen to a station 101.5 in New Jersey
The only thing that can be is that you have set a timer "sleep" function for that station. I have looked at the manual and it states you can programme a sleep setting for a radio station.
The instructions are on page 12. But I have extracted them below:
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
Jan 06, 2016 | Sharp CD-DH950 5-Disc Compact Stereo...
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
Station preset
If I have the same one; all you need to do is tune into the station you want to listen to. Then tap and hold on the preset you want to program it to. You will then see the p1 -p6 icon, which ever one you are programing will light up to indicate that you have set it. Its a little hard to see but if you have finger nails, the radio responds better. So in theory use a stylis when doing this it will be easier and much better to see.
Feb 02, 2014 | Ouku 7 Inch Car Stereo Radio Dvd Player In...
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
I can't connect to my Location Free base station remotely. The whole idea about the product is to watch your TV away from your home. Could anyone help?
Log into your LFP's settings page by entering the players IP address into your web browser. Then scroll down to access control and enable "Access via Global IP Address". It should start working right away
May 25, 2011 | Sony LocationFree Base Station
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Question 1: Find out the reasons those have made the UNIX an amazingly successful operating system. What are the Features on existing UNIX based operating systems like Linux Red Hat, Fedora and Ubantu...
Question 4: Consider the following set of processes that arrive in the ready queue at the same time:
Process CPU time
P1 2
P2 1
P3 4
P4 3
P5 1
P6 2
Consider the following scheduling algorithms: FCFS, SJF and Round Robin (quantum = 1)
(i) What is turnaround time of each process for each of the above
scheduling algorithms?
(ii) What is the waiting time of each process for each of the above
algorithms?
Jan 06, 2011 | Televison & Video
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Programming how to
there are quite a few models, but mine is the 'deluxe', and ther eis a 'program' button on the right side of the panel... .hold that down until it 'blinks' a number thru the LED screen. ...there are H and M buttons below the LED screen (one left, one right).... you can use those to program the hours and minutes.
if you are not sure what you programmed the time to be, u can always just hold down the 'program' button, and it'll flash with the set time.
when u go to sleep at night, just push the program button down, and it will light up, so u know it is 'set'.
Sep 24, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Hardware & Accessories Logo
51 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
