Question about Sony KDF-E50A12U 50" LCD HDTV
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Tried the scart lead and went through all av channels.got no sound or picture. the scart lead that was used is brand new.
    Top Expert:
  • Sony Master
  • 14,161 Answers
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Posted on Dec 01, 2014
3 Suggested Answers
sreekidu
  • 60 Answers
SOURCE: av channel change
Hi, please check if there is enough air flow where tv's ventilation is placed.. Try to keep a pedestal fan close to the tv's air flow holes and check if it happening again.. i think this will mostly solves your problem. If you go with this to your service centre they will simply replace the Tuner,and will give you heavy bill. all the best sreejith
Posted on Jul 16, 2007
eagle338
  • 4889 Answers
SOURCE: I have a Sony KDF-E50A11E,
So what exactly is the problem?Sorry I could not get it from your initial post. Please describe the problem in as much detail as you can so that I can help you solve your problem.
Sai.
Posted on Oct 23, 2010
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
I have sound but no picture please help
Make sure that your cables are fully plugged in and pushed into both your PS3 and your PS3. If you are using a standard scart lead, make sure that all 3 connectors are fully pushed in and are intact.
If you are using a HDMI cable, just make sure it's pushed in fully on both ends. If it still does not work, trying getting a new HDMI cable or scart lead, as they may be damaged in some way.
Oct 14, 2011 | Sony Playstation 3 (PS3) Console
No picture
could be electrical faults with the scart/HDMI lead. if your television has an ariel plugged in it be damaged by electrical currents, therfore a new scart lead or HDMI should do the trick
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
No sound or display
go back to your friend or another with a hdmi tv then connect the ps3... when connected go into the menu for display and switch output from hdmi to scart it should then work on your tv
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony KDF-E50A12U 50" LCD HDTV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
