Question about Motorcraft 1997-2004 Buick Regal Wiper Blade, 98-03 WW-22WA
Sometimes heater fan auto headlight and cruse all stop working at the same time
Nothing
  • 1,171 Answers
Check that the ground wires(white) are clean and tightened on the firewall under dash.
Posted on Dec 01, 2014
Why do both my headlights fail intermittently albeit infrequently sometimes, like tonight, in the dark, and then suddenly come back on again of their own accord? The heater fan's on same fuse.
My car did this and I found it less stressful to just go and get it repaired by some one who knows. Not sure what he did but it's working now .
Jan 11, 2016 | Cars & Trucks
Sometimes cruse heater fan and auto lights stop working
Check that the ground wires(white) are clean and tight under the dash on firewall.
Dec 01, 2014 | 1998 Buick Regal
99 Alero 3400 engine heater will not heat, also the cooling fans auto headlihts rear defrost do not work what should I check
CHECK HEATER AND AC ALSO DEFOGGER ON A 10 AMP IGNITION FUSE. FOR AUTO HEADLIGHTS CHECK AUTO MATIC LAMP CONTROL RELAY CHECK DAYTIME RUNNING LAMPS RELAY.
Dec 19, 2010 | 1999 Oldsmobile Alero
OUR 04 TRAILBLAZER, THE A/C STOPPED WORKING, IT WOULD WORK SOMETIMES AND BLOW COLD AIR NOW NOTHING COMES OUT, OR THE HEATER TOO.. LITTLE AIR WILL PULL THROUGH IF ON THE HIGHWAY, I CAN HEAR IT CLICK OVER...
a couple of things,1 blower motor fuse.2 blower motor gone out.3 switch on fan speed control switch not sending signal to fans.after checking the fuses.next check theswitch on control panel.set ac or heater.if fan still doesnt come on then replace it.when it work and then stops working there are a lot of possiblities that caused the prob relay too not fliping over inside staying close loop.hope this helps.
Aug 16, 2010 | 2004 Chevrolet TrailBlazer
Jedda dies sometimes
What is everything? does just the engine stops running, or does the heater fan and headlight stop too, does the the radio and parking lights stop working? does the starter engage after it stops? If you answer this question I will be able to help you.
Aug 24, 2009 | 2000 Volkswagen Jetta TDI
2001 Pontiac Grand Prix GT multifunction switch problem?
I had the exact same problem, I changed the "ignition switch" because the contacts inside were burned, this is why you see all those troubles coming in and out at different moments. It costed me 150$ to do it myself, buy the switch on an online reseller, must cheaper than the dealer! Now everything is back to normal on my Grand Prix GT 99 exept that my headlights don't light up automatically when starting the car... I have to check my fuse/relay and switch to make sure everything is ok on that side.
Good luck.
May 31, 2009 | 2001 Pontiac Grand Prix
Auto has 23K and cruse stopped working. checked
I had the same problem with my 2003 santa fe. Do you have any brake lights out in back? Weird as it is, as soon as I fixed a burned out brake bulb, my cruise worked again. The only relation I can think of is that tapping the breaks causes cruise to turn off - so maybe a broken brake/tail light passes a singal to cruise control from some reason???
Apr 07, 2009 | 2003 Hyundai Santa Fe
1998 Jetta my heater won't work, fan or nothing works on it
Try and giggle the switch, wears out sometimes, if not its probably the blower-engine thats done;)
Nov 28, 2008 | 1998 Volkswagen Jetta
Cruse control
Does your blower fan work on your heater/ac or your rear defrost work it could be the igniton switch were you put the key in. Turn the car on and off several times once you notice the cruise will not work and see if it starts to work if it does than it is the ignition switch this just happen to my 2003 century.
Sep 14, 2008 | 2003 Buick LeSabre
Motorcraft 1997-2004 Buick Regal Wiper Blade, 98-03 WW-22WA Logo
51 people viewed this question
Top Motorcraft Garden Experts
Dennis Key
Dennis Key
john h
Are you a Motorcraft Garden Expert? Answer questions, earn points and help others
