How do i repair the belt tensioner
Nothing yet
    Top Expert:
  • Washing Mach... Master
  • 44,926 Answers
Usually it is more practical to replace a damaged or defective belt tensioner rather than repair it.
Posted on Dec 01, 2014
I need a front of engine belt system diagram. I'm trying to replace all of the pulleys that have ball bearings. I'm not sure if Ther is 1 Tensioner Pulley and 1 or 2 Idler pulleys. .
Get yourself a chilton or haynes repair manual for your ride....it will give you a diagram of the serpentine belt. There is only one tensioner pulley but not knowing your ride or make I can't say....I
recommend an after-market repair manual for D Y mechanics!!!! On youtube is a how-to regarding the serpentine belt replacement but its probably not your model. Pepboys and other auto parts sell manual.
Jan 20, 2015 | Cars & Trucks
Replacing an alternator belt on a 2006 kia sorento
In most cases there is one tensioner that is spring loaded, you use a tool to push or pull the tensioner away from the belt to release the tension.
Make sure you have a diagram of how the belt is routed before you remove it.
Apr 14, 2013 | 2006 Kia Sedona
NEED INSTALION ON SERPENTINE BELT TIPS
1. A repair manual will be very helpful for this operation! If you cannot get one, then
2. Carefully observe the routing of the belt you will replace. Do you have one belt or two or more? make note exactly where they are. Draw yourself a "map" if you can.
3. Look for the "tensioner." This is usual a pulley by itself and usually has quite a bit of tension on the belt. Most tension pulleys I have seen press on the flat side of the serpentine belt. All of the accessories use pulleys with ribs that match the ribbed side of the belt. Carefully remove the tension from the belt. DO NOT pry off the belt! It should come off somewhat easily.
4. Compare the old belt to the new belt. They must have the same number of ribs and must be the same length. Keep in mind that the accessories that use that belt must line up so that the belt is not twisted even slightly.
5. Install the new belt exactly following the path of the old belt. It should go one easily and almost snug.
6. Apply the proper pressure to the tensioner and tighten the bolts for it. The instructions should tell you how much pressure you need against the belt for it to operate properly and safely.
7. After everything is hooked up properly and nothing will interfere with fans or other items, then start up the engine and listen for any screeching noises. Screeching noises, even if just for a second or two indicate the belt is either loose or not installed correctly. A belt that is loose or not fitted correctly will cause accessories to not work properly, cause damage to the new belt and possibly damage other parts of the vehicle. A belt that suddenly breaks can also cause serious personal injury, so please be careful!
8. If these instructions make you wary of doing the repair yourself, then take the vehicle to a professional who will give you a warranty for the work.
I wish you well.
Jul 16, 2011 | Dodge Ram 2500 Cars & Trucks
Need to tighten the belt and nothing looks movable. Anyone have a diagram?
it the belt is loose, the tensioner is bad. Its a pulley that should move and has spring tension on it. its a large pulley about 3" in diameter. replace the belt and tensioner.
Dec 09, 2010 | 1995 Saturn Sl
Need diagram for installation of a serpetine belt for 2005 Toyota Tacoma P/U 4.0. Please advise. Thanks
  1. REMOVE ENGINE UNDER COVER SUB-ASSEMBLY NO.1 (4WD AND PRE RUNNER DRIVE TYPE)
    1. Remove the 4 bolts, then remove the under cover No.1.
  • REMOVE FAN AND GENERATOR V BELT
    1. While releasing the belt tension by turning the belt tensioner counterclockwise, remove the V-ribbed belt from the belt tensioner.
  1. INSPECT V-RIBBED BELT TENSIONER ASSEMBLY
    1. Check that nothing gets caught in the tensioner by turning it clockwise and counterclockwise. If a malfunction exists, replace the tensioner.
    3. INSTALL FAN AND GENERATOR V BELT
    1. While turning the belt tensioner counterclockwise, align with its holes, and then insert a bar of 6 mm (0.24 inch) into the holes to fix the belt tensioner.
    2. Install the V-ribbed belt.
    3. While turning the belt tensioner counterclockwise, remove the bar.
    1. If it is hard to install the V-ribbed belt, perform the following procedure.
(1) Put the V-ribbed belt on all parts except the P/S pump, as shown in the illustration. (2) While releasing the belt tension by turning the belt tensioner counterclockwise, put the V-ribbed belt on the P/S pump.
  1. INSTALL ENGINE UNDER COVER SUB-ASSEMBLY NO.1 (4WD AND PRE RUNNER DRIVE TYPE)
    1. Install the engine under cover with the 4 bolts. Torque: 29 Nm (296 kgf-cm, 21 ft. lbs.)
Nov 21, 2010 | 2005 Toyota Tacoma
How to install timing belt 1995 sonata
YOU NEED A CHILTON REPAIR MANUAL.BECAUSE YOU NEED SPANNER WRENCH AND A LIST OF INSTRUCTION HOW TO REMOVE AND INSTALL THE TIMING BELT.I BEEN A MECHANIC FOR 23 YEARS I NEVER TACKLE ANY TIMING BELTS OR CHAINS WITH OUT A REPAIR MANUAL.REPAIR MANUAL IS A MECHANIC ROAD MAP LOST WITH OUT IT.SOUND LIKE YOU HAVE PROBLEMS WITH TIMING BELT TENSIONER LOOSEN THE TIMING BELT TENSIONER BOLT.INSTALL TIMING BELT ON THE CRANKSHAFT SPROCKET AND WHILE KEEPING THE BELT TIGHT ON THE TENSION SIDE ( RIGHT SIDE ) INSTALL THE BELT ON THE FRONT CAMSHAFT SPROCKET.INSTALL THE BELT ON THE WATER PUMP PULLEY THEN THE REAR CAMSHAFT SPROCKET AND THE TENSIONER.ROTATE THE FRONT CAMSHAFT COUNTERCLOCKWISE TO TENSION THE BELT BETWEEN THE FRONT CAMSHAFT AND THE CRANKSHAFT.IF THE TIMING MARKS BECAME MISALIGNED REPEAT THE PROCEDURE.INSTALL THE CRANKSHAFT SPROCKET FLANGE.LOOSEN THE TENSIONER BOLT AND ALLOW THE SPRING TO TENSION THE BELT.TURN THE CRANKSHAFT 2 FULL TURNS IN THE CLOCKWISE DIRECTION ONLY UNTIL THE TIMING MARKS ALIGN AGAIN.NOW THAT THE BOLT IS PROPERLY TENSIONED TORQUE THE TENSIONER LOCK BOLT TO 21 FT LBS.
May 17, 2010 | 1995 Hyundai Sonata
I need 2004 Hyundai XG350L Service/repair Manual
3.5L Engine
Remove or disconnect the following:
  1. Negative battery cable
  • Engine coolant
  • Water pump pulley bolts
  • Alternator bolt, loosen only
  • Water pump pulley and drive belts
  • Crankshaft pulley
  • Timing belt cover(s)
  1. Turn the crankshaft until the timing marks on the camshaft sprocket and cylinder head are aligned.
  2. Loosen the timing belt tensioner bolt and turn the tensioner counterclockwise as far as it will go. Tighten the adjusting bolt.
  3. Mark the timing belt with an arrow showing direction of rotation.
  4. Remove the timing belt.
  5. If defective, remove the timing belt tensioner.
Timing belt sprocket alignment mark positioning for belt removal and installation—3.5L engine
To install:
  1. If necessary, install the timing belt tensioner.
  2. Attach the top of the tensioner spring on the engine coolant pump pin. Ensure the hook on the pin is facing down and the hook on the tensioner is facing away from the engine
  3. Rotate the timing belt tensioner to the extreme counterclockwise position. Temporarily lock the tensioner in place.
  4. Align the timing marks of the camshaft and crankshaft sprockets.
  5. Install the timing belt on the crankshaft sprocket, then onto the rear camshaft sprocket.
  6. Route the belt to the coolant pump pulley, the front camshaft sprocket and the timing belt tensioner.
  7. Apply force counterclockwise to the rear camshaft sprocket with tension on the tight side of the belt and check that timing marks are aligned.
  8. Loosen the tensioner bolt 1–2 turns and tighten the timing belt to a tension of 57–84 lbs. (260–380 N).
  9. Turn the crankshaft two turns clockwise.
  10. Readjust the sprocket timing marks and tighten the tensioner bolts.
  11. Install the timing belt covers.
  12. Install the crankshaft pulley and tighten to 108–116 ft. lbs. (150–160 Nm).
  13. Install or connect the following:
    • Crankshaft pulley
    • A/C compressor belt
    • Water pump pulley
    • V belt
    • Negative battery cable
    • Engine with coolant
Feb 10, 2010 | 2004 Hyundai XG350
Passenger side shoulder strap doesn't tension properly on 88Vette
have you checked the tension when the brakes are being applied some of the newer vehicle seat belts don't tighten until you step on the brakes
Jul 15, 2009 | 1984 Chevrolet Corvette
Drive Belt
I am not too familiar with your vehicle, but if it has a serpentine belt there is a tensioner that keeps tension on the belt. Most tensioners have a area where a 1/2" ratchet or breaker-bar can be inserted to release the tension. The tensioner is nothing more than a spring loaded pulley, so look for the pulley that seems to be doing nothing.
May 31, 2009 | 1995 Mazda 626
A/c pwr steering drive belt keeps coming off
If you have set the tension correcly when replacing the belt there are a couple of things that could be going on. #1 it is possible that the belt itself is the wrong length or width. Be sure that the belt you have is a good replacement for your make and model. Also I have repaired a vehicle that had this problem and it was because of the tension roller was freezing up and not moving the belt along properly so replacing that roller fixed the problem. Also, if the angle of one of the aspects of what the belt goes over is slightly cockeyed it can cause the belt to come off as well. I would suspect the length or width of that belt is your problem. Make sure that you have the correct belt, set the tension properly, check all the angles of the devices it rolls over and make sure nothing is slow, bound or not moving(frozen up) and this problem should be fixed. Good Luck
Nov 06, 2008 | Mitsubishi Eclipse Cars & Trucks
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
