Question about Pontiac Vehicle Parts & Accessories
Have no spark at all 4 coils on my Pontiac vibe 2004. replaced head rebuilt, set timming to correct marks,all components back in place.engine cranks over but no spark to plugs?
Exhaust cam went bad, sheared pin on cam shut down engine. towed home tore down, replaced rebuilt head etc .set timing to correct marks cranks but no park to plugs codes po 351a,352b,353c,354d came up ignition coil malfunction?
    Problem Solver:
How about the crankshaft sensor wire?
Posted on Dec 01, 2014
ENGINE CRANKS BUT WON'T START
Runs basic tests. Spark at plugs? Correct fuel pressure? Compression test.
Jul 29, 2015 | 2010 Pontiac Vibe 1.8L
Lancer timing
-Try one more time. When pull out the plug, make sure ground it.
If there is spark shown. It could be the rotor point to the wrong cylinder plug wire.
Mai
Nov 11, 2013 | 2002 Mitsubishi Lancer
2004 lancer won't sart
have you got the timing set correct ,and did you fit the timing belt with all the timing marks lined up ,etc , if there correct ,check for spark ,by pulling off a spark plug lead and fitting an old plug into the lead ,then crank the motor ,dont hold the plug with your hand ,use insulted pliers ,if you have spark, ,if no spark check coil wiring ,coil, crank angle sensor,
Jun 08, 2012 | Cars & Trucks
When im going down the road my 2004 pontiac hesitates you have to give it more gas
tune up, maintenance and likely an air filter required
Most new vehiclwes have a hesitation but if it is a definite lag then try the above
Jun 11, 2011 | 2004 Pontiac Grand Prix
Engine misfires on number 4 cylinder
have a tech pull the codes from the computer, misfire code can be system or component generated ,however if the misfire is only a specify cylinder i t may be narrow down to sticking,clog,fautly injector or circuit,spark plug or wire shorted coil and or ciruit also fuel and compression ,further information needed code are codes perform power balance and relative compression test
Feb 25, 2011 | 2004 Pontiac Vibe
How do I replace 2004 Pontiac Vibe passenger side tail light assembly?
Hello Tim.
Here is the procedure.
  1. Open the rear compartment lid.
  2. Remove the rear compartment trim panel (4).
  3. Remove the tail lamp socket (2) from the tail lamp(7).
  4. Remove the tail lampbulb (1) from the lamp socket (2).
There you are, Happy New year.
KL
Jan 01, 2011 | 2004 Pontiac Vibe
On a rebuilt motor how do you set the timming on a 350 chevy. Thanks.
firing order is 1 8 4 3 6 5 7 2 remove number one spark plug its always the right drivers side head..closest to the radiator turn engine crankshaft till the top of number one piston is all the way to the top or if you have help put your thumb over the plug hole sand have someone bump the engine over till the pressure in the cylinder pops your thumb free,,,check front of crank  harmonic balancer for timing mark if you need to move crank by hand till the mark lines up to the 0...or top dead center....then make sure distributer cap is pointing to number one plug wire if not remove dist and turn to the right position and install...if it dosnt go in all the way dont worry hold light down pressure on it  and just bump the engine over and it will drop right in place then recheck your settings and install spark plug start engine and adjust with timing light check your specs
Mar 07, 2010 | 1983 Chevrolet K1500
2007 PONTIAC VIBE CRANKS, BUT WONT FIRE.
it is still under warrenty. take it back to the dealer.
Jan 28, 2009 | 2006 Pontiac Vibe
2004 Pontiac Vibe FWD
Take off the annoying plastic engine cover...you'll see them towards the back(I'm almost definite).
Jul 23, 2008 | 2004 Pontiac Vibe
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
Jeff Turcotte
Jeff Turcotte
Dan Shibata
Dan Shibata
Jerry Pecor
Jerry Pecor
Level 1 Expert
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
