Question about Diesel Black Label DZ9047 Watch for Men
A black label
Set the time day days in month
    Champion:
  • 238 Answers
Google
Posted on Nov 25, 2016
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do i set the time and date on my watch?
This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
or
You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
Thanks for using Fixya. Please rate the solution.
Nov 06, 2010 | Armitron 165 watch
How do you set the day and month?
Mcdevito75 here, The stem on your Timex shou;ld have two (2) positions, slip a finger nail just under the crown and gently lift to the first position, it may take a little practice to get but you will. In this first position you"ll see by turning the crown one way you can change the date (number) and turning in the other direction you can change the month or day, if so, set the day and date to one (1) day before the day and date you want. Push the stem back in and lift the stem all the way to set the time of day, now cycle thru the watches 24 hours to set the day and date you want. Your Timex is now set and will change at the proper time of around midnite. If your Timex has the month and day you may have to cycle the 24 hours to reach the correct month other than that these instructions should help.
Aug 09, 2010 | Timex T21553 Watch for Men
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Nov 05, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
Nov 03, 2009 | Bulova Watch
How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch. "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
Mar 15, 2009 | Watches
Change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Oct 15, 2007 | Timex Men's Black Reef Gear i-Control...
Diesel Black Label DZ9047 Watch for Men Logo
20 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
randymanfive
Are you a Diesel Watch Expert? Answer questions, earn points and help others
