Question about Jeep 02-04 Grand Cherokee Original Stereo Cass Cd Radio
Dash lights and radeo don't work
Checked fuses
  • Jeep Master
  • 1,493 Answers
Fuse check good, has to be a ground wire(white)under dash on firewall needs cleaned and tightened. Always check the ground.
Posted on Dec 01, 2014
My two idiotlights don't come on when you turn key on and head lights don't work. have replaced ing. switch with no change
check for a fuse near the engine to tractor wiring connector. check battery cables for looseness & corrosion. tighten the ground cable where it connects to the chassis and inspect the engine to chassis bolts. loose connections can cause backfeed problems, such as when you step on the brake pedal in your car, and can then turn on the radio...
Dec 16, 2012 | Garden
Brake Lights and Turn Signals don't work
Check fuses should be under dash or glove box & bulbs
Jun 12, 2012 | Cars & Trucks
Dash lights and tail lights don't work
Lights and electrical circuits are sometimes in pairs so that you notice something is wrong (tail lights and dash). On a '90 merc grand marq., that would be fuse #4,the 15 amp blue one, in the panel next to your left foot. If you are lucky,it
just failed from age. If you are not lucky, there is a short in the system containing
the dash, tail,parking,side marker, license lamps and trailer tow relay if equiped.I had to replace the push/pull main light switch which was shorted. If you are lucky, just replacing the fuse in the panel will do it. Referance Grand Marquis Owners Manual for fuses and function.
Apr 12, 2012 | 1990 Mercury Grand Marquis
Dash lights don't work 1992 jeep wrangler
try turning the headlight knob left to right several times, and jiggle the switch at night. Also check your fuse panel should be a 10 amp or less fuse that says "Insr" or something like it.
Nov 11, 2011 | 1992 Jeep Wrangler
1997 eclipse dash lights not working i know there are two fuse boxes i dont know which one o look at and which fuse it is help?
Your tail lights, license plate ights, and side marker lights are protected by the same fuse that supplies power to the dash lights. Hint: if your other lights are working, the fuse is NOT blown and you don't have to spend time looking for it.
The next thing that deserves mention is the fact that the dash lights are controlled by the dash light rheostat (dimmer switch). Make sure you don't have them turned off with the switch.
If after reading the above, you still think you need to find the fuse, it is fuse #5 (15 Amp) located in the dedicated fuse and relay box in the engine compartment. It is most likely marked "Taillight Relay".
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 18, 2011 | 1997 Mitsubishi Eclipse
Dash lights are out replaced all bulbs, where is the fuse box located?
If ALL the bulbs don't work the fuse is the first place to check. Fuse is labeled PANEL 7.5 amps under the dash, left side. above drivers feet. did you try turning the DIMMER knob?
Sep 02, 2011 | 1998 Toyota Camry
I have a 1996 dakota with no tail lights. The brake lights work. I think it may be a fuse, but I don't have a manual to see what fuse it may be,????
Why would it be a fuse?
You have front parking lights? Then no fuse
If it was a fuse ---would that fix it -- NO it wouldn't
Why do fuses blow?
Have you even removed the tail light housing & checked the bulbs,
or checked the sockets for ground or under truck for wiring
harness issues?
Don't need a manual to check all fuses under the dash &
in the box near brake booster
Jul 01, 2011 | 1996 Dodge Dakota
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
Jeep 02-04 Grand Cherokee Original Stereo Cass Cd Radio Logo
65 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
