Error SC 671 - Office Equipment & Supplies
  • Office Equip... Master
  • 3,368 Answers
Yes, that should be answerable but first read the instructions they contain some amazing information. we can not help you because we have no idea of what you have.
Posted on Dec 02, 2014
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
What is the sp mode richo aficeowhat is the sp mode richo aficeo
he following error messages will appear on Gestetner, Lanier, Ricoh and Savin products control panel. There are no codes listed in service for operator/user problems. SC-101 Exposure lamp, lamp stabilizer board, dirty white plate, dirty optics, SBU board, CCD SC-103 Power problem SC-104 Exposure lamp problem, main relay optics board, electrical noises or communication error SC-105 Zero cross, main relay, optics board, FUSE 804 on DCPS or AC drive board on FT series SC-120-123 Scan home problem, sensor, scan motor, (EX-IPU board or fuse FU103 Aficio 400, 401, 500) SC-121 Scan home or fuse FU4 Scan home or fuse FU106 Aficio 550/650 SC-124 Scan motor encoder or scan motor SC-125 Scanning to slow speed SC-126 Scanning too fast speed SC-127 Scan motor or optics board SC-128 Scan start speed wrong; motor, board, drive section SC-129 Scan speed problem; motor or PSU SC-130 SBU error SC-140 / 141 Lens vertical home sensor SC-142 / 143 Lens horizontal home sensor SC-144 /145 3rd scan home sensor problem SC-190 EX-IPU board Aficio 400, 401, 500 Optics thermistor FT 7950, 7960, 7970 series SC-192 Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate SC-193 APS sensor FT 7950, 7960, 7970 series SC-194 IPU white level detect (too low) same as 192 SC-300-303 Charge corona SC-302 Laser (polygon) motor problem SC-302 Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650 SC-303 Charge corona wire cleaner, disconnected or time out for printer SC-304 Charge roller problem, ID sensor problem SC-305 Time out error for memory or EX-IPU board or fuse FU103 on Aficio 400, 401, 500 SC-310-314 Potential sensor SC-320 Laser motor problem SC-321 Laser write problem, BCU board, EX-IPU board SC-322 Laser 1 synch. Problem SC-323 Laser drive problem SC-324 Laser drive excess current draw problem SC-326 Laser 2 synchronization error SC-327 Laser 1 home position error SC-328 Laser 2 home position error SC-329 Laser beam pitch error SC-330 Laser diode no initial setting SC-331 Laser diode home error SC-332 Laser diode present position error SC-335-338 Laser motor polygon problem SC-340 TD sensor output error SC-341 Developer motor lockup TD sensor adjust error Aficio 551, 551P, 700, 700P SC-342 TD sensor adjust error SC-345 Toner collect motor lockup Developer bias loss Aficio 551, 551P, 700, 700P SC-346 Toner recycle motor disconnected SC-350-1: thru 5 ID sensor error SC-351 Vsg problem, bad drum, ID sensor SC-352 TD (toner density) sensor problem or bad toner mix SC-353 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-354 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-355 Toner density sensor or under toned SC-356 Toner density sensor or over toned SC-358 Image density sensor, drum, toner spray SC-360 Hard disk drive error 1 SC-361 Hard disk drive error 2 Incomplete drum potential calibration, check imaging formation assembly FT 7950, 7960, 7970 SC-362 Image compression error Hard disk drive error Aficio 551, 551P, 700, 700P SC-363 Data transmission error SC-364 Data transmission time out error Vd out of specs, drum, drum potential sensor, charge corona FT 7950, 7960, 7970 Hard disk drive error Aficio 551, 551P, 700, 700P SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970 SC-366 CRC error Aficio 550/650Vr out of specs, drum, drum ground FT 7950, 7960, 7970 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-367 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-370-01 thru 07 Drum potential sensor error Aficio 550/650 SC-370-374 IMAC error Aficio 551, 551P, 700, 700P SC-376, 380, 382, 384, 386, 388 Data transmission problem Aficio 551, 551P, 700, 700P SC-390 CRC error Aficio 551, 551P, 700, 700P SC-390-1 Toner density sensor error SC-390-2 Toner density sensor error SC-391 Developer bias problem or FU103 on Aficio 550/650 Image storage address error Aficio 551, 551P, 700, 700P SC-392 Toner density sensor SC-395 Developer bias problem SC-400, 401 Transfer roller error Aficio 551, 551P, 700, 700P SC-401 Transfer roller positive error problem SC-401-1 Transfer roller/belt short SC-401-2 Transfer roller/belt open or fuses FU104, FU115, FU116 Aficio 550/650 SC-402 Transfer roller negative error problem or open SC-403 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Scanner problem; BCU, EX-IPU board or SCU on Aficio 400, 401, 500 SC-411 Separator bias SC-430 Quenching lamp error SC-440 Main motor locked or drum motor locked SC-441 Developer motor locked SC-490 Exhaust fan problem or ozone fan problem SC-491 Laser cooling fan locked SC-492 Cooling fan problem SC-493 Bridge fan problem Exhaust fan locked Aficio 551, 551P, 700, 700P SC-494 Fuser fan locked SC-495 Toner recycling unit problem SC-496 Toner collector bottle problem SC-497 Toner recycling motor problem SC-500 Main motor locked Bypass motor locked FT 7950, 7960, 7970 SC-501-1 & 2 1st Tray lift problem SC-502-1 & 2 2nd tray lift motor problem SC-503-1 & 2 3rd tray lift motor problem SC-504-1 & 2 4th tray lift problem SC-505 LCT tray SC-506 Optional tray motor locked SC-507 LCT motor locked SC-508 Tandem rear fence motor SC-509 Tandem side fence motor SC-510-1 & 2 LCT lift problem Paper feed motor problem Aficio 551, 551P, 700, 700P SC-511 Tandem side fence motor error LCT motor error Aficio 551, 551P, 700, 700P SC-515 Tandem rear fence motor Aficio 551, 551P, 700, 700P SC-516 Tandem side fence motor Aficio 551, 551P, 700, 700P SC-520 Duplex or fuser drive problem FT 7950, 7960, 7970 SC-521 Duplex side fence drive problem SC-522 & 523 Duplex jogger home position FT 7950, 7960, 7970 SC-524 Duplex end fence drive problem SC-530 Bypass motor locked or fuse FU106 on Aficio 551, 551P, 700, 700P SC-531 Fusing duplex motor locked SC-541 Fuser thermistor open SC-542 Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P SC-543 Fuser temperature to high SC-544 Fuser temperature too low SC-545 Fuser temperature to high SC-546 Fuser ready temperature unstable SC-547 Zero cross problem Fuser lamp stays on, AC drive board, optics board FT 7950, 7960, 7970 SC-548 Fuser unit not installed SC-590 Toner collector motor problem Cooling fan Aficio 220/270 series SC-591 1 bin tray motor SC-600 Communication problem between SCU and operation SC-601 Communication problem between BICU and scanner Communication problem between BCU and EX-IPU board Aficio 400, 401, 500 Communication problem between SBU and SBICU Aficio 550/650 Communication problem between MCU and BICU Aficio 551, 551P, 700, 700P SC-602 Communication problem between BICU hard disk drive board Communication problem between BCU and fuser control unit on Aficio 400, 401, 500 Communication problem between Hard disk drive board and SBICU Aficio 550/650 Communication problem between BICU and hard disk drive board Aficio 551, 551P, 700, 700P SC-602-2, 2, -3 Communication problem between BICU and ADF SC-604 Communication problem between BCU and high voltage board SC-605 Communication problem between SCU and BCU SC-610 Communication problem between IOB and duplex unit SC-610, 611, 612 Communication problem between BICU and ADF SC-620 Communication problem between BICU and ADF SC-621 Communication problem between BICU and finisher SC-623 Communication problem between BICU and paper tray unit SC-624 Communication problem between BICU and LCT SC-625/626 GA5 data transfer error; EX-IPU or software Communication problem between BICU and finisher Aficio 551, 551P, 700, 700P Communication problem between BICU and LCT Aficio 1035, 1045 SC-627 Communication problem between BICU and LCT Aficio 1035, 1045 SC-630 Communication problem between line adapter and CSS center (Japan) SC-635-636 Communication problem between BICU and paper feed board Aficio 551, 551P, 700, 700P SC-640 BICU data transfer sum check error SC-641 BICU control data transfer problem SC-650, 653 Key card (Japan) SC-670Engine or BICU error SC-672 Op panel to controller problem SC-690 BICU problem (12C) SC-691 Communication problem between BICU and fax controller BICU problem (12C) Aficio 1035, 1045 SC-692 Communication problem between BICU and print controller board BICU problem (12C) Aficio 1035, 1045 SC-694 Communication problem between BICU and scanner board SC-696 Communication problem between IOB and finisher SC-700 ADF P/U problem SC-701 ADF P/U problem SC-702 ADF feed in motor SC-703 ADF transfer motor SC-704 ADF feed out motor SC-705 ADF bottom plate motor SC-720 Finisher transport drive motor problem SC-721 Finisher tray shift or shift motor problem SC-722 Finisher jogger motor SC-723 Finisher stack feed motor problem SC-724 Finisher stapler hammer motor SC-725 Finisher stack feed out motor SC-726 Finisher shift/lift motor SC-727 Finisher stapler rotation motor SC-729 Finisher punch motor SC-730 Finisher stapler position motor SC-731 Finisher exit guide motor Finisher exit open/close motor problem Aficio 1035, 1045 SC-732 Finisher up tray shift motor problem SC-733 Finisher stack feed out motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-734 Finisher lift motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-735 Finisher exit guide motor Finisher pre-stack motor Aficio 551, 551P, 700, 700P SC-736 Finisher exit guide plate motor SC-737 Finisher waste stapler full SC-738 Finisher shift tray lift motor SC-740 1000 sheet finisher error 01: Shutter error 02: Exit error 03: Upper exit plate error 04: Jogger motor 05: Stapler motor 06: Stapler hammer motor 07: Tray lift motor 08: Shift tray height sensor 09: Back up RAM 0A: Communication error SC-741 1000 sheet finisher error in saddle stitch area o 01: Position plate motor o 02: Folder roller motor o 03: Shutter guide motor o 04: Booklet jogger motor o 05: Stapler motor o 06: Folder plate motor o 07: Connector o 08: Switch SC-750 Interchange connection problem SC-751 Bridge connection SC-752 Finisher connection SC-760 ADF gate problem SC-770 Shift tray motor SC-800 Control board bad SC-804 Control board bad SC-819 Software application error SC-820 Control board or software SC-821 Control board SC-822 Bad HD SC-823 Bad control board or NIC SC-824 NVRAM or battery bad SC-826 NVRAM bad SC-827 Memory problem SC-828 Bad control board or firmware SC-829 RAM DIMM or control board bad SC-835 Control board or connector SC-836, 837 Font ROM bad SC-838 Clock generator problem SC-850 NIB or control board bad SC-851 IEEE 1384 interface board or control board bad SC-860, 861 Hard drive problem, connection or cable SC-862, 863 Returned, Bad sector in hard drive SC-864 Abnormal HD data transfer SC-865 Hard drive error SC-900 Electrical copy counter problem reached 10 million or NVRAM problem SC-900-01 Mechanical counter SC-901 Mechanical counter or fuse FU4 SC-921 MSU hardware error Copier feature expander hardware error Aficio 220/270 SC-940 Main switch problem or main board SC-951 Gate signal error SC-953 Scanner image setting error (Software) SC-954 Printer image setting error SC-955 Memory setting error SC-956 Scanner parameter error SC-957, 958 Scan error SC-959 Printer setting ID error SC-960 Printer return ID error SC-961 Printer ready ID error SC-962 Memory setting ID error SC-963 Memory finishing error SC-964 Printer ready error SC-970 Scan error SC-980 Program loading error or hard drive access error SC-981 Hard drive response error SC-982 Hard drive construction error SC-984 Hard drive response error Control board, BICU or connection bad Aficio 1035, 1045 SC-985 Control board, BICU or connection bad Aficio 1035, 1045 SC-986 Software problem SC-990 Communication problem between BICU and input output board or software performance error SC-991 Software problem SC-996 FCU board or firmware problem SC-997, 998 Software or missing RAM or missing DIMM SC-999 Program version error or fuser FU6 Program download problem, BICU, IC, NVRAM bad, power loss, board installed wrong Aficio 1035, 1045 Printer Controller Error Codes 2001 Power on error 2002 FGATE error 0201 On board SDRAM error 0301 SDRAM error 0Fxx Controller -BICU error 1101 Data transmission error 1102 Data loop back 11xx Centronics cable error 1401 Controller NVRAM error 1402 NVRAM check sum error 1403 NVRAM white error 1404 NVRAM read error 1501 RTC error 1601 Font ROM error 1602 Data in font ROM is damage 1Bxx Options bus A error RICOH 3813 Copier U1 Right side open U2 No key counter U4 Sorter not latched or closed U6 Developer unit not in place E11 Exposure lamp problem E12 Exposure lamp problem E13 Zero cross, main board or power supply E-14 Zero cross, main board or power supply E-21 Scan home problem E-22 Scan home problem E-28
May 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
107 people viewed this question
jasbo
jasbo
