Question about Panasonic KX-T7735 Corded Phone
How to store speed dial on panasonic KX-T7735
No clue so far
    Top Expert:
  • Panasonic Master
  • 74,118 Answers
Http://service.us.panasonic.com/OPERMANPDF/KXTAW848.PDF Check this link to download the user manual to this phone. It has all details. http://electronicshelponline.blogspot.com/
Posted on Dec 01, 2014
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
Posted on Jan 17, 2009
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730- assigning speed dialing/one
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Posted on Jun 04, 2009
cnavarro
  • 2460 Answers
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Posted on Nov 09, 2009
Phonesmith
  • 113 Answers
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
cnavarro
  • 2460 Answers
SOURCE: changing all speed dial numbers
Speed dials reside in programming memory 001. You can change them from the maintenance console software, or an extension, usually on Jack #1, operator, or the manager's phone.
From the phone, (ext 101) press PROGRAM and dial **1234. If the display says SYS PGM then dial 001 and start with your first speed dial number (3 digit, 001-999). By stepping through the ENTER key, you will be able to find the existing numbers. A trunk access code must be the first part of a speed dial number. You probably see it as the first digit "9" in front of all your numbers.
Carl
Posted on Apr 10, 2010
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Our KX-T7735 phone system is not working, yet our phone service is live. Is there a code we need to unlock?
Have you tried pushing to CO button and then dialing out?? Otherwise unplug the phone from the wall and power, pull batteries and wait half hour and reconnect.
Nov 13, 2013 | Panasonic KX-T7735 Corded Phone
How can i se the numbers i have received and the missed calls in my panasonic phone KX-T7735
Hello, I have a Kx Td1232 with a KX-T7735 and program 96 and 99 does not work. What do I have to do? Thank you.
Sep 14, 2011 | Panasonic KX-T7735 Corded Phone
Wow to reset the one touch dialing
It depends on the system. In a TA series, it's PROGRAM button 2 STORE. In a TAW or highter it's PROGRAM button TRANSFER STORE.
Carl
Mar 27, 2011 | Panasonic KX-T7735 Corded Phone
Verizon voice mail notification on panasonic kx-t7735 phones
Wow. It's customary to start with and understand the manual to your phone system. CO message waiting is done on a TA-824 system. I'm guessing that Verizon uses stutter dial tone and those options are turned on via the 3.4 section of the maintenance tool or programs 435, 436 and 437.
If any of the above is foreign to you, then you need to either call your dealer or start reading.
Carl
Jan 14, 2011 | Panasonic KX-T7735 Corded Phone
How do I change the clock on the panasonic kx-t7735
www.westlake.co.uk/KXT7700-User-Guide.pdf
http://www.retrevo.com/support/Panasonic-KX-T7735-Telephones-manual/id/2915ag913/t/2/
Hi please find above your user manuals to download, inside it explains it all step by step...
Nov 08, 2010 | Panasonic KX-T7735 Corded Phone
Hello, I have the panasonic kx-t7735 and the mess...
Message waiting can come from different sources and is set up by pressing the MESSAGE button, or in some systems dialing 4 after you place an intercom call. However, on a display phone, you can tell who left the message by pressing MESSAGE and looking at the display :-)
To cancel all MW, in a TA, on the intercom, dial 700+0. On a TAW-848 and TDA, dial *700+your extension. On a TD, it's 700+your ext.
Carl
May 20, 2010 | Panasonic KX-T7735 Corded Phone
How can i reset speed dial numbers?
The manual is online: http://www.fixya.com/support/p123658-panasonic_kx_t7735_corded_phone/manual-7398
Nov 18, 2009 | Panasonic KX-T7735 Corded Phone
I have a panasonic KXT TA624 pbx. my phone line just stopped working. it says "CO not assigned"
From the phone press PROGRAM the button and dial 0 1 or 02 or 03 whatever line it was then STORE
Carl
Jul 04, 2009 | Panasonic KX-T7735 Corded Phone
Panasonic KX-T7735 Corded Phone Logo
150 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
