Oce plot wave 750 error code 05701 showing optimizing printing coming how can we fix the problem
SOURCE: Error in Oce 9400 Plot Director Win 2000
There are a few possible solutions.
First, only the last version of Plot Director (3.4.3) works in Windows 2000, so make sure that is the version being installed.
Secondly, once PD is installed and uninstalled all registry references must be removed before attempting to reinstall or you will encounter errors.
Third, make sure you have Administrator privileges when installing or editing the program.
Last, because there has been no development on PD since 2001 it may be having issues with security, such as the ability to edit files that are in a protected zone or communicating thru a firewall.
As a test make sure that none of these programs are active during installation or configuration.
Posted on Mar 03, 2009
Joed911
  • 4338 Answers
SOURCE: 0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 18, 2009
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Posted on Oct 10, 2009
ginko
  • 19396 Answers
SOURCE: I have TCS500 Oce plan
Hi.
The code is not reported in service documentation, but the problem is likely the encoder ruler.
Clean and check position and state of the encoder strip. This is the plastic ruler located behind the printheads, and it is the part that determines the position of the printheads.
Encoder Strip. Wipe clean with a lint-free cloth and alcohol only. Take extra care to not bend the strip.
In case the part is broken (you will notice), I think that it is listed as encoder ruler here. Call Oce to confirm before replacing.
If you think that the comment was helpful, then please do not forget to accept the solution. Your feedback is important for us.
Posted on Sep 21, 2010
Oce Colorwave 600ps errorcode 16702 what does it mean?
The media output sensor didn't detect the media in time.
Ensure that you are not pulling your plot out before the CW600 actually delivers it. The CW600 stops printing, cuts the plot, delivers it to the top delivery tray, but pauses for a second before fully delivering it to the tray. See if you get the same problem if you output to the rear. If this problem persists, please call an authorized Oce/Canon service representative.
Apr 06, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce Plot Wave 300. What does error 22701 mean?
The cause can be trying to place new programs over old one that aren't fully uninstalled or malicious software.
Scan and repair any missing or damaged window registry files use RegCure Pro
maximize and eliminate use spyhunter
Jul 25, 2015 | Office Equipment & Supplies
Our Oce Plot Wave 300 is going through toner very fast. The toner waste bottle is supposed to last through two toner bottles but fills up in less than one bottle. The OCE technician has looked at it but...
Dear
the service engineer is right, Pl. check the resolution of the printer, next check the toner cart. if possible try disconnect the ground connection to the doc.blade.
Thanks.
Mar 03, 2015 | Office Equipment & Supplies
Oce tds600 error code in 05701
This is a "developer pollution" error. You probably are getting a message referring to a failure to optimize what you are trying to print.
That being the case, perhaps a change of the "ink" is in order or whatever you can do to clean the machine as something something is gumming up the developer..
This OCE is a Cannon company. If your manual has no cleaning instructions, you are at the mercy of techs familiar with doing the process for your machine. Or, you might get lucky with tech support of Cannon. Typically, manufacturers would be about the only ones able to identify what such codes means. Hope this helps.
Nov 09, 2014 | ErrorExpert Computers & Internet
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Colorwave 650 error code
This is a no toner detected error inside the print head or "Imaging Device". Sometimes a toner pearl misses its mark and bounces out of the tube, although this is rare. If you reboot the system after the printer has cooled down, see if the problem returns. If it does, there could be a problem with the toner dispenser or a problem with the print head itself.
Apr 12, 2014 | OCE Office Equipment & Supplies
Sir, Print coming out like a sign wave..
sir i have a canon ir3300 machine its print clarity and neetness
but the problem is coming print out is in a waves how can i solve this
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
427 people viewed this question
jasbo
jasbo
