Question about Renault Megane Coupe 20 Model Kit
<!-- from fixya rte -->Why will engine turn but not fire - Renault Megane Coupe 20 Model Kit
  • 6 Answers
You can perform some simple tests to find the root cause. Spray some starter fluid down the engine intake ( this may be difficult on fuel injected cars, you may have to remove an intake plenum). After spraying the starter fluid, attempt to crank the car. If it hits and runs briefly, then you may have a fuel system issue. Check the electric fuel pump. If the car does not attempt to start or run, then the engine may have 'jumped timing'. The timing belt of the engine, especially on small foriegn cars, has to be changed at certain mileage intervals. If it has jumped timing, you will need to have the car towed to a shop.
Posted on Dec 01, 2014
Engine turns over wont fire
well you have to check to see what it is not doing,check to see if you battery is fully charge then check to see if your spark plugs are firing if you have fire check for fuel then for fuel pressure,then compression
Jul 21, 2014 | 1996 Dodge Dakota
Mazda 323 firing order, is it clockwise on distributor cap
on the four stroke right hand ( clockwise ) turning engine the firing order is 1-3-4-2 but there are some exceptions on European model. The firing order is also clockwise set because your engine is right hand turn. For you if you like to see also what I stated you can remove the distributor cap if you know how,and by starting the engine you will see the rotor arm turning clockwise.
Jul 05, 2014 | 1993 Mazda 323
Engine is not firing,motor turns over but doesn't seem to be firing
what year make model engine etc.................................
Feb 01, 2013 | 1994 Honda Accord
Can't git engine to fire know fire from coil.
Rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Sep 06, 2012 | 1989 Nissan Pathfinder
1.8l 4 cylinder wont fire after replacing head cylinder?
rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Aug 29, 2012 | Cars & Trucks
1995 Mazda 626 -what is the firing order on a 2,5lt engine? I have # one turned to the top and the timing mark on the crank is right on but the rotor is on #6 plug. Doesn't make sense to me. When I turn it...
I read that the firing order was '1,2,3,4,5,6' which is easy to remember: prev.gif next.gif FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: 1.5L, 1.6L, 1.8L (except K8) and 2.2L Engines Firing order: 1–3–4–2 Distributor rotation: Counterclockwise 89542g14.gif
Fig. 2: 1993–97 2.0L Engine Firing order: 1–3–4–2 Distributor rotation: Clockwise 89542g15.gif
Fig. 3: 1998 2.0L Engine Firing order: 1–3–4–2 Distributorless Ignition System 89542g16.gif
Fig. 4: 1.8L (K8) and 2.5L (except 1998 626) Engines Firing order: 1–2–3–4–5–6 Distributor rotation: Counterclockwise 89542g17.gif
Fig. 5: 1998 2.5L (626) Engine Firing order: 1–2–3–4–5–6 Distributorless Ignition System 89542g18.gif
Fig. 6: 2.3L Engine Firing order: 1–2–3–4–5–6 Distributorless Ignition System 89542g19.gif
Jul 04, 2010 | 1995 Mazda 626
What is the firing order for a grand cherokee laredo. I change the distributor for sgrand cherokee laredo jeep. I lined up tdc, had the rotor turned to number 1, but it is still missing.
You didn't post your engine size so please choose the apprpriate diagram:
1989-98 2.5L Engine firing order: 1-3-4-2 Distributor rotation: Clockwise
2.8L Engine firing order: 1-2-3-4-5-6 Distributor rotation: Clockwise
4.0L Engine firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
5.2L and 5.9L Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
May 12, 2010 | 1996 Jeep Grand Cherokee
Engine turns and turns but does not fire
you will have to check the coil for fire.
sound like coil went bad
Jul 18, 2009 | Garden
Renault Megane Coupe 20 Model Kit Logo
106 people viewed this question
Top Renault Toys Experts
xxxxxx xxx
Travis cook
Are you a Renault Toy Expert? Answer questions, earn points and help others
