Door would not open and red light indicating check drain came on?
Draining the water from the bottom
Clear the blockage
and reset the machines error condition detection
or it will stay there
look up how to reset
Posted on Dec 02, 2014
bd8078
  • 12 Answers
SOURCE: miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Posted on Oct 03, 2008
  • 63 Answers
SOURCE: water leak at door but seems to come from door itself.
no seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Posted on Nov 15, 2008
mgprice
  • 744 Answers
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Posted on Nov 09, 2009
SOURCE: Water pours out from soap/softener drawer at top...
I'm guessing, what with this having been posted nearly a year ago, that this has been resolved, one way or another, but I thought I would post this solution for the benefit of others:
We had this same problem, where water was flowing out from underneath the detergent dispenser. The problem we had was a blockage between the dispenser and the drum, so after taking the console and door-panel off the washer, I removed that black tube from the dispenser to the drum and pulled out the matted-up sock which had somehow made its way there. Good luck!
Posted on Nov 13, 2009
beltronic205
  • 1474 Answers
SOURCE: Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Posted on Dec 16, 2009
My machine is showing a message f 05 pls help
Hi.
F-05 indicates a draining problem. Disconnect power. Move the machine forward. Check the hose at the back of the machine. Try running a cycle with drain hose down in a bucket.
Check also the drain pump filter, most Hotpoint front loaders have the access door in front at the bottom. Open drain filter door, undo drain cap, collect water using a container. Disconnect power before starting.
Aug 06, 2011 | Hotpoint Washing Machines
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
Why does my machine blink f 21 when it starts to fill then it stops and does nothing
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 06, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water is left in the bottom of the dishwasher after completing a cycle
When you find water left in the bottom of the dishwasher... most of the times there is an "Intake/Drain" flashing, or some other type of fault indication. The dishwasher has faulted out, in the middle of a selected program. The dishwasher won't even bother to drain the water out. If it's not a drain fault, then you can drain the water out by: switching the dishwasher off and on again; selecting a program; and closing the door. Open the door after 15 seconds and see if the water has drained out. If it didn't drain, there is a drain problem. If it did drain, then it can be several things. To better determine the problem, you will have to pay close attention to when the dishwasher faults out.
Nov 20, 2010 | Miele Premier-Plus Built-in Dishwasher
Our MIELE TURBOTHERMIC shows a red indicator light on the topic of: drain/watersupply.when switched off and restarted, it evacuates the water succesfully and commences the cycle but then after two minutes,...
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Dec 26, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Water in bottom, and it wont turn on
my neighbor fix it, don't know how.
Jan 09, 2009 | Dishwashers
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
