I have a presto heat dish that I needed to replace the wall cord to. I cut off the old one, stripped the wires and attached the New plug. Whe plugged in the buzzer kept sounding, so I removed the plug and reversed the two wires. This tome it buzzed for a moment and one does not work at all. I originally replaced the plug because it had shorted out and sparks had come out of the plug. It had also flipped a breaker. Can it be repaired?
2 Suggested Answers
SOURCE: Presto Heat Dish buzzer
I have no doubt that a previous post meant well with the suggestion to remove and bypass the tilt (or "tip") switch but this a very dangerous thing to do. It costs the manufacturer money to incorporate these safety features. It cuts their profit margin so believe me they wouldn't include them if it wasn't absolutely necessary. To eliminate this switch would disable the unit's capability to not only warn you with the buzzer of an upset condition but also ensure that the element will stay on when lying on it's side on the floor!! The only way the heater "knows" that it has been tipped is from this switch opening up and splicing it's wires directly together will forever prevent the detection of an upset heater. If you fall asleep with the unit on and the pooch brushes past it, knocking it over, it will lie on your nice carpet or wood floor silently cooking anything it touches and the alarm won't sound even when you need it. Don't set yourself up for an easy fire.
The buzzer is wired in series with the heating element (coil) and without the two safety switches it would stay on forever (the round button-like devce at the top of the reflector dish is a temperature high limit switch there to prevent a runaway heat condition). These two switches actually short circiut the buzzer so current will flow only through the heater element under normal operation but if either switch opens current can now flow to the alarm buzzer as well. Since the buzzer adds a lot of resistance to the coil/buzzer path it severely reduces the available shared current to the point where the coil won't heat up but since the buzzer only needs a fraction of what the coil does, it sounds off.
Incidently, that high temperature switch can be tripped off (turning on the buzzer) by a dirty reflector because the dirt or crud spilled on the dish prevents full reflection of the developed heat, dramatically increasing the temperature near the limit switch (as a white surface under the sun reflects heat while a black surface absorbs it). It usually takes a few minutes for this to happen. When the switch resets the cycle repeats. However if the alarm sounds immediately for no apparent reason at start up, either switch or the associated wiring will be open circiut.
Many electrical devices that I have serviced have different sized connectors to prevent mixing up their positions when reassembling but these units use identical sized spade terminals so make sure you note their original locations before pulling them off. Transposed wires may appear normal but cause many and varied new problems. Wires normally are routed to avoid strain so if one looks like it is stretching too hard to reach it's terminal it's probably in the wrong spot.
Posted on Feb 20, 2009
I have a Coleman mach RV roof Ac with a fan and separate Furnace unit. None of the units will turn on.The AC did work along with the fan. Now nothing works. All of the fuses are good
Check the plug end of the Power cord for a broken wire. If you can test the cord for continuity with an ohm meter do that first. Most likely you can get a replacement plug. You'll need to cut the old one off and strip the wires back to connect the new plug.
Feb 09, 2017 | Coleman Heating & Cooling
My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
May 28, 2016 | JBL ONSTAGE Docking Station for iPod
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
Jan 23, 2015 | Furniture
How do I replace Dyson DC24 plug
Cut off the old plug end with wire cutters. Next, strip off the outside cover of the cord about and inch off. This will expose the black and white wire inside. Then strip off the coating on the black wire and white wire. Take your new plug end and slide the plug over the cord. Use a phillips screw driver to wire the black and white wire to the terminals.
Sep 05, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Hi, one of the audio phono leads has packed up on my Technics 1210 after all these years. Have cut off the actual input jack (white) and was wondering how best to go about adding a new one. I thought this...
Hi, Replacing the rca plug at the end of the cable is just a matter of splicing the wires correctly. The wire is actually a 2 wire line, almost directly under the black outer casing will be the ground wire ( is actually going to be totally wrapped around the center wire ) this will be evident if you look at the cross section where you cut the cord. The replacement end can be purchased at the local Radio Shack, less than $3 probably for a pack of 2. When stripping the casing from the cord be carful not to cut away too much of ground wire sheath ( this may lead to difficulty in attaching new end ) it is almost inevitable to have a few strands of wire cut loose. The next step is to sort of " part " the outer sheathing, then kind of wrap both halves around the inner conductor as close to where you stripped outer sheathing away as possible. Next strip away the inner wires sheathing and you have the two ends to either solder, if you know how to, or tie through the holes of the replacement rca plugs leads. I hope this was of enough help and thank you for asking FixYa, Good luck-Prodzilla
Apr 16, 2011 | Technics SL-1210 Turntable
Plug Flamed & burned carpet when heatdish was turned on
hi check the connetions on the heater plug and the cord replace if brunt then try it again ?
Feb 23, 2010 | Presto HeatDish Compact Heater
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Feb 16, 2010 | Simplicity Vacuums
How do I open a Kenmore 116 Vacuum?
You shouldn't need to remove the cord just to put a new plug on. Just cut the end off about 2 inches back, strip the outer insulation and the wire ends and install the new plug. Make sure there are no stray strands of wire hanging out from under the screws. I always solder the ends, so that I am dealing with a solid wire rather than twisted strands.
Sep 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
