Question about Whirpool Refrigerators
Hi when i plug my whirpool american fridge freezer in it keeps blowing the electrics , please help
Ive tried other sockets and it still blows and have changed the fuse
    Top Expert:
  • Whirpool Master
  • 26,089 Answers
Compressor faulty?
Posted on Dec 01, 2014
SOURCE: American fridge freezer - sansumg rsh1dtmh
I had the same problem. There is a circuit board on the very top of the fridge/freezer. There is a 5amp quick blow fuse on there. Sounds like that has blown. Mine did for performing the same function. replaced it and all is good.
Posted on Feb 20, 2008
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
  • 56 Answers
SOURCE: my whirpool 6th sense american fridge freezer has
Be very careful, when the ice maker malfunctions, many things can be the culprit. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
machinetech7
  • 1344 Answers
SOURCE: Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Posted on Jun 18, 2012
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Is the vent on the side of the crisper suppose to blow out cool air?I have a whirpool side by side..8years old
No, that vent is for the return air going back to the freezer. The vent at the top is where the freezer fan blows air into the fridge.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hello I own a whirlpool Fridge + Freezer.
Hi lewis,
This is very suspect if it blew straight away I would suspect the compressor going to earth, I am still not convinced with the comp after all ts ten year life is up, It could be something to do with the thermal overload on the comp if it has one.
The compressor does run for 12 hours but in that twelve hours does it reach temp? does it actually switch off on its normal routine?
where about in the uk are you?
Jun 29, 2009 | Freezers
this samsung fridge freezer diy channel may help ckick here
also check this video ....http://www.youtube.com/profile?feature=iv&user=SamsungFridgeFreezer&annotation_id=annotation_526429
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
61 people viewed this question
Top Whirpool Refrigerators Experts
Andrew Taylor
Andrew Taylor
ray gallant
Your Consultant
Are you a Whirpool Refrigerator Expert? Answer questions, earn points and help others
