Question about Sansui 50IN E-LED TV 1080P SLED5000
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
TV used to work, suddenly it was not powering, took it back to store, and they switch it on and it worked, they took it for assessment at sansui, it came back fine, took it home, switch it, and still not getting power, tried all the plugs in the house, none can power it, but my PS3, 2 laptops, Moderm, DSTV HD PVR, and all electrical appliancec in the house are working fine, only the TV not getting on, took it to friends house, TV goes on fine.
    Top Expert:
  • Sansui Master
  • 74,459 Answers
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
Posted on Dec 01, 2014
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 520 Answers
SOURCE: Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Posted on Jan 07, 2009
SOURCE: I have a Sansui HDLCDVD260,
I have a same Sansui HDLCD 2600 which did not have anything happen when try to switch on. no lights even on the power led. where can I get the replacement parts?
Posted on Jun 28, 2009
  • 520 Answers
SOURCE: Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Posted on Jul 17, 2010
pan_stak
  • 182 Answers
SOURCE: i want to know that
you have to mention your exact model but according to Sansui, LCD TVs can play DivX and Mpeg4 format files
Posted on Jul 28, 2011
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Can't get the hd on my tv to work with the hdmi cable - i only have one port in the back of the tv - the tv was taken to a friends house who tried the hdmi cable through a pc into the tv and it works
if it worke at your friends house then it must be the cable or what you are trying to use via the HDMI cable some devices turn of HDMI if it has been unplugged and you have to manually turn it back on itn setting. its a bit hard to do on some as they don't have a scart socket. but if you turn of the device for about half hour and have the HDMI lead in and turn it back on it will reset to HDMI. its a surge protector.
Oct 03, 2013 | Televison & Video
No sound on certain channels.
All the apartments complex have it than it not ur tv.It the cable company signal problem.Tell the maneger call talk to the company check the wiring.
Jan 13, 2010 | Toshiba 19LV610U LCD TV
My tv cycles off and on ,by itself.
Try a power drain to see if can keep the TV on consistently:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV continues to turn off and on after this, it would appear that there is an issue with the TV's power supply as it may be on it's last legs.
Mar 25, 2009 | Televison & Video
Power will not work
look inide your house/apartment for the breakers panel - usually in the basement/ground floor closet for house or in the closet for aprtments-check that breakers are on the ON position-plug another appliance in the same plug (example clock or toaster) see if it works-if another apliance works it is an internal problem with the power supply to your tv-get back to me with the model of the tv
Oct 04, 2008 | Televison & Video
LG 42pc3r, Starting problems.
First thing to try is a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this doesn't solve the issue, it sounds like your TV's connection between the power supply and the mainboard is defective. If the power supply was shot, you would hear nothing at all. I hope the above step helps.
Sep 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Infrared sensor not working
try changing your remote's battery and look for loose connections inside the remote control
Dec 05, 2007 | Sharp 25R-S100 25" TV
Is my tv screwed
When you bring somithing from the cold to a warm place. Wather condensatin to the cold surface, it can case a lot of problem!
But after a 30min 1h you can pug in the device without a problem.
So if the device working dont have to worry about it.Just dont do this again.
(Electrical Technician)
Nov 12, 2007 | Televison & Video
Sansui 50IN E-LED TV 1080P SLED5000 Logo
62 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
