Question about Dyson Vacuums
Why does the brush on my dyson 39 not work
Have taken cleaner apart suction good but brush bar does not work
  • Official Brand Answer
  • 2,572 Answers
Hi Anne, it's Jack at Dyson.
If your DC39's brush bar won't rotate, but you're confident your vacuum has strong suction, we'd be keen to take you through some further troubleshooting checks when you have your machine to hand. If we can determine that there's an issue with the Triggerhead floor tool itself, we can confirm if we can replace this for you under the free Dyson parts and labour guarantee.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Posted on Dec 04, 2014
    Master:
  • Dyson Master
  • 851 Answers
HI, it's Jim from Crucial Vacuum!
If your vacuum has good overall suction, but the brush roll itself isn't turning then it's definitely not a clog within the vacuum but rather a blockage near the brush roll. Here's some help examining your Dyson vacuum's brush roll.
Right off the bat is there any noticeable debris caught in it? You are mainly looking for long carpet fibers, or even strands of hair. If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely.
You can purchase replacement filters for your Dyson DC39 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc39-pre-filter-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Dec 01, 2014
    New Friend:
  • 25 Answers
Partially blocked air suction flow?
The selector plunger for hard floors will not operated brush head.
check position of plunger selector.
https://www.dyson.co.uk/...is-not.../turbine-head-not-working-properly
SOURCE: Dyson vacuum no suction
Clean the mini cyclones in the Canister or clean the filter.
Posted on Oct 07, 2007
  • 3 Answers
SOURCE: Dyson lsoing suction
There is a guide to pulling apart the Dyson DC05 to replace a burnt out motor at www.tasweb.org
Posted on Jan 14, 2008
chrispurs1
  • 372 Answers
SOURCE: dyson
Hi.
If the brush turns freely then you will need A new clutch unit fitted to your machine.
There are loads of them on Ebay very reasonabley priced only buy new not second hand.
Manuals are available to show you how to strip down the machine from here http://dysonmanuals.llc.nu/
Posted on Jun 29, 2008
ukvacfan
  • 328 Answers
SOURCE: Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Posted on Apr 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: Dyson Animal with no suction from floor brushes
Check the canister seal for dirt or gaps. This is normally where the vacuum leak is.
Posted on May 14, 2009
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
    The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
    Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
    I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
    With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
    Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
    Loss of suction
    Hi there, it's Jack at Dyson.
    I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
    However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
    http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
    The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
    I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack - Dyson Online Customer Support
    http://www.dyson.com
    Jun 09, 2013 | Dyson DC44 Animal Cordless Vacuum Handheld...
    Why doesn't the Dyson work at base with brushes
    Hi Barbara,
    I'm sorry to hear you're having difficulties with your DC14. If your machine has suction through the wand, but not through the cleaner head, it's likely that there's a blockage somewhere in the cleaner head. The filter may also need a wash.
    The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=622&product=DC14-ANIMAL_US
    This should resolve the issue - however, if you'd like further assistance, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US) so we can help.
    Kind regards,
    Jack
    Nov 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    The brush for my dyson works when engaged in the down position, however, the vacuum turns off when in upright position. I'm not sure if the suction is on when using the rotating brush since I cannot...
    The advice we'd recommend would depend on the model of Dyson cleaner you own, which you haven't specified in your question. As a general rule, on most Dyson upright models, the brushbar is designed not to run when the cleaner is standing in the upright postion. However, the suction motor will continue to run, to allow you to use the hose, wand and dusting tools.
    If you're concerned about your cleaner, it's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Jul 29, 2011 | Vacuums
    My Dyson 14 Animal seems to not have the suction
    Hi its Darran at Dyson.
    Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
    If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
    I would recommend washing the filter if it hasnt been done for a while.
    You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
    I hope that this information is useful to you.
    Kind regards
    Darran
    Apr 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    348 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
