Question about HP Officejet Pro X476dn Color Inkjet All-In-One Printer, Copier, Scanner, Fax
How do fix,hp officejet pro x 476 ,problem with printer or ink system.
    Top Expert:
  • HP Master
  • 75,581 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 01, 2014
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
After 7 yrs, suddenly the ********* cartridge is not recognized, no red light, why?
HP Officejet Pro 8500 will not recognize changed ink cartrid ...
h30434.www3.hp.com > Printers, Copiers, Scanners and Fax > Inkjet
Laptops & Tablets Laptops & Tablets .... HP Officejet Pro 8500 will not recognizechanged ink cartridge ..... I have a hard time believing that something that worked just fine until it ran out of ink, suddenly has a broken sensor. It's barely 2 yrs old. ... show any ink, replaced them all and after 5 minutes of 'thinking', ..it worked.
Epson cannot recognise a cartridge:16 ways to solve the ...? 6:33https://www.youtube.com/watch?v=bc04OM9ZRXkNov 4, 2013 - Uploaded by viandant5The red ink light remains on after replacing an ink cartridge. - The printer is not recognising one or more ink cartridges. ... Via Beverara 224/7 ... Printer cartridges not detected - How to fix - Duration: 2:41. by Thriftyink 102,951 ...Epson inkjet printer rejecting printer cartridges
Dec 21, 2015 | Office Equipment & Supplies
How do I put a new ink cartridge in
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/4117382113001/replacing-ink-cartridges-on-the-hp-officejet-6810-and-officejet-pro-6830-e-all-in-one-printer-series/video/
May 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
How do I clean HP officejet Pro L7680 All pictures have severe vertical lines??
Have you tried the "clean print head" option in the HP Officejet Pro software on your computer? This will often fix verticle lines. But, it will use a lot of ink.
Nov 04, 2014 | HP Officejet Pro L7680 All-In-One Printer
I get broken gear in my hp officejet pro 8500a
Someone pulled hard on jammed paper to remove it from the printer. This has broken the small plastic paper advancing gear on the left-hand side of the printer (have seen this mistake a number of times). The printer is broken and cannot be fixed, and it is time to purchase a new one. What you and everyone needs to learn from this is to NEVER pull hard to remove paper out of your printer. Be careful, and open the access doors to get to it.
We would suggest that you upgrade to an HP 8600 series printer and if you print more than 500 pages per month you purchase an AdaptiveInk continuous ink supply system (CISS). Adaptive Ink Continuous Ink Supply System Home Page Adaptive Ink HP Pigment ERC
Mar 12, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
Here are some steps can help you.
Use only New Original HP ink
Restart the printer
Rreseat the ink cartridges
Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
Restart the printer.
I hope this will be able to help you resolve the issue.
Thank you for choosing Fixya.
Mar 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Whant to buy Hp 88 Printhead
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=ca&dlc=en&lang=en&cc=ca
click "Shop For Supplies" to access:
https://h30042.www3.hp.com/SureSupply/
Which of the HP 88 cartridges:
C9385AN HP 88 Black Officejet Ink Cartridge
C9386AN HP 88 Cyan Officejet Ink Cartridge
C9387AN HP 88 Magenta Officejet Ink Cartridge
C9388AN HP 88 Yellow Officejet Ink Cartridge
do you need to order?
Nov 20, 2009 | HP OfficeJet Pro k550 Printer
HP Officejet Pro X476dn Color Inkjet All-In-One Printer, Copier, Scanner, Fax Logo
mukhtar21 shaikh
mukhtar21 shaikh
