Question about Electrical Supplies
Where is low oil sensor aan a digital inverter generator
    Scholar:
  • 132 Answers
Look on the engine block . There should be a wire on it to the engine ignition magneto.If the engine runs the low oil sensor is not the problem. If the oil is full and the engine has no spark try disconnecting the wire from the low oil switch if you get spark the low oil switch is bad.replace stitch and reattach wire and fill oil to proper level
Posted on Dec 04, 2014
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
I have a eu3000 is honda generator i have replaceil and controdule and i still have no fire why
Check the ground wire that goes from the negative side of the battery to the engine block. I have seen them break at the connection on the block. You can test to see if it is broken by connecting a wire from the ground lug on the side of the generator and holding it to a bolt on the side of the engine and see if it will start. Also the low oil sensor will prevent the spark if you are low on oil.
Aug 30, 2014 | Honda Eu3000is
RYOBI 1000w Digital inverter generator. ...will not start... we have followed the instructions provided and we cannot get the genny to fire up..... oil level is fine, switches on the correct position,,...
have had the same problem with a Ryobi 1000w invertor generator. The problem that you are experiencing is the low level oil switch. To confirm if this is the problem disconnet the low level oil switch (Yellow or Orange wire). Try and start the generator now, it should start with the first little tug on the recoiler. Once it is running, reconect the low level oil switch and see what happens then. Either it will cut out, then you know it is the oil level switch or it will continue running and the problem will go away. Please ensure you manually check the oil level first before starting.
Aug 04, 2014 | Electrical Supplies
Why does my honda generator cut out after 20 seconds?
either you have a crankcase with low oil or overfilled and contaminated with fuel.fill oil to first thread of filler and try again,if overfilled by fuel then you need to clean the carburetor float it may be obstructed.if oil okay and continues to shut off you may have a faulty low level sensor.
Jun 23, 2014 | Honda Electrical Supplies
I have a eu 6500is generator inverter that will run perfectly for any amount of time, then with no warning just stop generating and idle. No overload alarm. No oil alarm. Nothing will just idle. If you...
this sounds like a capasitor/resistor that is getting hot under load once it is switched off and cools down it works until it gets hot again similar to that of a cars ignition coil which will get hot and cut the vehicle out but once it cools it will start again.
Dec 07, 2013 | Honda EU6500iS Inverter Generator
How do i disconnect the low oil sensor
Some oil sensors will stop the generator from running if unplugged, IE they close the circuit on oil pressure, some close the circuit on oil pressure. I wouldn't recommend but with it running just take the single wire off the sensor, if it stops immediately then it requires the signal grounded to run. Some ground on low oil.
Oct 26, 2012 | Coleman Powermate Subaru 5000W Portable...
I have a centurion 3250 watt portable generator it was working fine 2 days ago but it will not start. Will not being on a level and flat surface cause it to not run ?
Hi and welcome to FixYa, I am Kelly.
Your question:
"Will not being on a level and flat surface cause it to not run?
In short YES!
Generators have low oil level sensors that are quite fussy about their orientation. If there are any inclinds a generator is sitting on you can get FALSE low oil level shut downs.
You must make sure the generator is full of oil and I do mean FULL. Additionally do what you have to so that the generator sits level horizontally.
A quick way to find out if the low oil level sensor has been activated is to simply check spark.
If you have no spark:
FILL WITH OIL
Re-orient generator to a level position (15 to 30 second wait)
(Check spark again) If you now have spark your low oil level sensor had gounded the ignition because it sensed a low oil level either from an actual low oil level condition or the unit was on an incline causing a false low oil level senor activation and a subsequent engine shut down.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | Electrical Supplies
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Sep 09, 2009 | Honda Electrical Supplies
Starting
try checking the oil. it might be low
Jun 09, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Electrical Supplies Logo
143 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
