Question about Dishwashers
The model as heater warms the water during the wash cycle and has stop working on the 45 c and eco50 c wash but heats water on 70 c wash so is problem on the circuit board
Check the filling pipe filters and filter on the discharge side
  • 14 Answers
SOURCE: Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
Posted on Sep 13, 2007
  • 49 Answers
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Posted on Feb 19, 2008
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
SOURCE: No pressure during wash cycle
check capacitor on motor. possibly not turning at correct speed
Posted on Jun 10, 2008
bigg t
  • 640 Answers
SOURCE: AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Posted on Mar 02, 2009
Please tell me if an NA VR5500L Panasonic washing machine has a water heater? If it does, how does it work? the drain coming out is cold. THANKS A LOT
The only appliance that heats water internally for cleaning is a dishwasher. Washing machines don;t heat water. It's not efficient. Various industries have work their hardest to keep you from using hot water or the chemicals(phosphates) that help you clean better without it. Dishwashers warm 3 gallons no more than 20 degrees during a 30 minute cycle. Some washing machines are designed to avoid hot water completely and call themselves energy effient to get people to buy them. My wife would cut my heart out if I brought one home.
Aug 24, 2015 | Washing Machines
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Bosch wfl2000 machine works on every cycle apart from spin, washes drains etc but wont spin. Cheched brushes and removed and had motor tested all ok, belt fine, any ideas- Controller!!
are you sure its heating the water as it will not complete the wash cycle if the heater has failed, hence not getting to the spin cycle. try testing heater or see if water is warm coming out or glass warms up
May 31, 2011 | Washing Machines
Sometimes during night several times try to start
it sounds like the fflame sensor needs to be replaced, however if the unit has fan assited combustion you may also have an issue with the pressure switch. hope this helps
Nov 02, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Mar 16, 2009 | GE WBVH6240F Front Load Washer
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
