How to set date, clock etc?,on Ultronic Model # ws9
Reset and lost everything. I've been able to set time when 12pm came on, even tho it's am/ the year showing is 2007 ! without a date. Over the calendar is an S only. Can you help me I have no manuel
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Posted on Mar 11, 2007
cuppajoey
  • 3 Answers
SOURCE: HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Sep 19, 2008
SOURCE: How do you set the clock/calendar on the Canon MP25DV?
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay.  same with the date.  You kinda need to play around with it.  Thats how i learned.
Posted on Oct 07, 2008
  • 3 Answers
SOURCE: Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Posted on Jan 13, 2009
SOURCE: MP11DX time and date will not set
I just did it over and over again, I think I may have even hit the = afterl. To change the AM hold down the calendar key, then the div
Posted on Jul 14, 2009
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
Ultronic Touch Screen Thermo Alarm Clock TD552 Desktop Model
This may be helpful, it's how I set mine.
1) Remove battery cover
2) Remove batteries
3) "Set" the clock and battery cover into the trash can.
There you go. No more problem !
Mar 15, 2010 | Computers & Internet
HOW SET THE DATE AND TIME FOR A "ULTRONIC " WORLD TIME CALENDAR
I have a ultronic TDoo552 clock that I cannot set. HELP
Sep 06, 2009 | RIM BlackBerry Pearl 8100
How do I set the date and time
First set to "Rate Set"
Then enter the month, day and year seperated by a "." then hit the Clock/Date button. So 7-7-09 would be entered as 7.07.2009.
It's the same idea to set the clock. You use a 24 hour period. So 4:12pm would be entered as 16.12.
Jun 09, 2009 | Sharp EL-2196BL Calculator
Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Feb 19, 2009 | RIM BlackBerry Pearl 8100
Ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Nov 03, 2008 | RIM BlackBerry Pearl 8100
Setting an ultronic clock
Press "Mode" once to view the calendar
Press Mode again to view the alarm time
Set Time:
Press and hold Mode for 3 sec. to enter the time setting...Hour blinks..change by using Up or Down buttons. Press Mode again to set Minutes Press Mode to finish
Set Calendar:
Press Mode to see calendar
Press Mode for 3 sec to set year. Year appears, blinks...change with up or down buttons
Press Mode ..month appears...blinks. Change with up & down buttons. Repeat for day. Press Mode to finish
Jun 14, 2008 | RIM BlackBerry Pearl 8100
61 people viewed this question
k24674
jasbo
jasbo
