Question about Acer Computers & Internet
My PC has no display...what happened? i already check the power supply its ok...and the cable...please help
I check the power supply and the VGA cable...when i power on the cpu fan is ok but no display
    Scholar:
  • 162 Answers
Check the led light indicator of your monitor. Is it green or blue? Or is it yellow or orange? If it's green or blue, then there's no problem with your monitor. If it's yellow or orange, you may have a defective or dirty graphics card or memory.
Open your system unit chassis, remove the video card (if you have) and the memory or RAM from their slots. Clean the gold contacts or pins with a rubber pencil eraser, then wipe it with a lint-free cloth to remove the debris. Then put it back again to their slots. Test.
There's a lot of instructional videos on youtube on how to remove these parts properly, so better watch them first if it's your first time.
Hope this may help you, please rate my answer. Thank you for using fixya.
Posted on Dec 02, 2014
PcExpert
  • 293 Answers
SOURCE: Power problem
NO POWER Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver. FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 20, 2007
SOURCE: gx260 pc wont start
Either the motherboard or power supply are bad. I've had both be the cause of the problem. Check the motherboard for bulging and discolored capacitors. The same can be true of the power supply.
To the guy above who said his were out of warranty. If the motherboard is the cause of the problem, Dell will replace it until near the end of January. Just call them up and try to convince them. We are an educational customer, but everyone should be able to get it. It's a known defect.
Posted on Dec 18, 2007
CLUEPATEL
  • 138 Answers
SOURCE: CPU fan not working
This problem is due to your Powersupply! Get your powersupply checked and if necessary get it replaced with new. Avoid repairing.
Posted on Jan 06, 2008
  • 998 Answers
SOURCE: No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Posted on Feb 12, 2009
Monitor does not come on
Hi Scott,
please check the removing the vga cable of monitor and turn its power on and display must show no signal error itself you can see it very clear text on it.
if your monitor good check the cable and plug it back to pc.then turn on the pc.if computer starts you can hear the HDD sound and please note the Beep sounds comes up or not ,if continues beep comes up problem can be with your pc memory modules or vga card ,sometimes mother board,
clean the ram card using smooth brush and mother board also.
unplug the power supply jack and re insert it .
remove the vga card also and do the same.
first all check the power unit fan is turning on when you press the power button too...
please let us know the results or come with more details.
regards.
nuwan
Jan 08, 2014 | Dell Dimension 3000 PC Desktop
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
Its not showing anything but it has power
please check whether the VGA cable is properly connected to your monitor and CPU and check. it should work. if not try with another cable.VGA cable and Pin will be blue in colour
Feb 13, 2011 | ViewSonic VA703B LCD Monitor
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
May 27, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Power on nothing on montior
1. Take out the battery
2. Attach the power cable only (no battery)
3. If you are not getting any power then the problem is either with your power cable or your power supply
Mar 15, 2010 | HP OmniBook XE3 Notebook
Power but no display acer aspire L100
Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
- check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
- if your RAM OK, check your VGA
- if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
hope this will help you.
Jun 07, 2009 | Acer Aspire L100 PC Desktop
Monitor turn dark frequently
it sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Feb 11, 2009 | Acer Computers & Internet
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
