How to use my canvio connect to back up files and system on my PC xp laptop.
Plugged it into laptop USB. Now what? I have no instructions.
    Genius:
  • 1,552 Answers
Open "My Documents".
Click with the RIGHT mouse-button on the file/folder that you want to backup.
Choose "Send To".
Choose the drive-letter associated with the external disk-drive.
Posted on Jan 01, 2015
4 Suggested Answers
SOURCE: Computer tells me "WDDM service not running"
If you want to back up files on to your external hard drive, you don't need the wddm program. Microsoft Windows usualy comes with a back up program. just open up the windows help and search for back up. and open the back up your files option and then click the link that says click to open backup and restore center. Follow the on screen instrucions and save the files to your external drive. I have an external drive, and I recomend that you do not back up yor files. This is only usefull for saved games. backing up music and movies takes to long. What I do is move all of my music and video files over to the external drive and I can acess them drictly from the drive itself. you can't do that if you back the files up, the files end up being commpressed into a zip file of some sort that says backup drive. when I installed my external drive, it was given a drive letter. I open up my computer and itsays My Book - with drive letter G. I click on it like it is a regular drive and I can save stuff to it. I save my videos to this drive and can watch them at any time. If you want to back up files I recomend unchecking the back up music and video options and saving music and vide files in the manor that I mentioned earlier. Then back up all other files and it will get done much quicker as these files usually are not near as big as music and video files are. So you can ignore the error message and be carefull not to download any updates for these drives. I did this and the drive came up with an error message that told me that my new drive was defective and needed to be replaced. I was angry so I took it back to the store, and replaced the broken drive for the same one. I will never again install any updates for my external hard drive. the error message said something about having no drivers, but the help info for the drive said that the drivers are automatically installed for all windows opperating machines. once again I urge all people with the western digital My Book essential and simmilar drives - stay away from those bad update files!
Posted on May 15, 2010
Testimonial: "Thank you very much for the info"
  • 6 Answers
SOURCE: buffalo external hard drive fell while connected
you probably damaged the drive if you cant see any of the files in wich case either the data is lost or the drive may even be destroyed
Posted on Mar 05, 2011
  • 29 Answers
SOURCE: i have toshiba basic canvio
The files may be lost, so you lose access to these files. You can use a file recover software to get lost files back from USB drive.
Posted on Nov 18, 2013
How do I retrieve my files from Canvio Basics 3.0?
The usual way to back up files is to just open my computer and open the drive that is the external hard disk and just drag and copy the files over. You would then do the same this king to drag the files back to your computer. I am assuming you did not do this and usedsome software that came wwith the drive. In that case I would still open the drive in my computer to see if its there or otherwise u need to use the same software u used to backup the files to recoverthem. If you ccan't figure it out I would redo saving the files the normal way like I explained before . An internal hard drive or even external storage device like USB thumb drive simply shows upas a new drive when plugged in. Do not use an software to save files as usually they are proprietary and use compression which is iinconvenient or makes it difficult to recover
Jul 24, 2014 | Toshiba 1TB CANVIO BASICS EXTERNAL USB 3.0...
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
Will the toshiba canvio desktop 3tb hard drive work with the LG 47LM6700 tv?
Depends on the format your hard drives in (personally I'd just use a PC with an HDMI cable) and whether your TV supports USB file reading.
Nov 30, 2013 | Toshiba 3tb Canvio Desktop External Hd
Can't run NTI Backup software on Windows 7
Have you installed the proper USB 3.0 drivers.
If not install the USB 3.0 drivers that support your motherboard.
Dec 11, 2012 | NTI Backup Now EZ
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Toshiba 750 canvio
POR FAVOR QUIERO LA CONFIGURACION DEL DISCO DURO EXTERNO ... Y EL REGISTRO PARA REGIRTRARME
Sep 23, 2012 | Toshiba Canvio 750 GB USB 3.0 Portable...
Lost all data on lap top
The operating system files may have been deleted and the laptop cannot boot up. To get the laptop operating again you can try a Windows Repair, failing that you need to install Windows again.
To do a Windows Automatic System Repair for Windows XP, follow the instructions from this WEB site -
http://www.helpwithwindows.com/WindowsXP/howto-18.html
To do a Windows Automatic System Repair for Windows 7, follow the instructions from this WEB site -
http://windows.microsoft.com/en-AU/windows7/help/system-repair-recovery
To recover your data before you install Windows - remove the hard drive from the laptop and connect it to the USB hard drive adapter then connect it to a working computer's USB port. This computer will see the USB hard drive adapter and hard drive as an external storage device, you can then open the folders and files on the hard drive and copy the data files to the computer and to backup your files.
Apr 13, 2012 | Advent Computers & Internet
C0000218 Registry File Failure on Fujitsu Laptop
Chances are when you reinstall Windows Xp you will lose your data.
You can recover your data by removing the hard drive from your laptop and plug it into an USB hard drive adapter and connect this to a working computer's USB port. This computer will see this as a external hard drive and you will see the various folders and files.
Copy and or burn your data folders and files to a CD.
Then put the hard drive back into your Fujitsu reinstall Windows XP.
Jul 12, 2009 | Fujitsu Computers & Internet
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
6-29-2008 I have a Maxtor One Touch 4 Mini that I use to back up files on my desk top and also want to use it to transfer the same files back and forth with my laptop. Both the Desk Top and the Lap...
After following the on-line instructions I replaced the USB cable that came with the Maxtor with a difrent one and now the drive works as it should. I do not know what the problem is with the original USB cable.
Thanks for the follow-up
Glenn Alford
gamafay@aol.com
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
