Question about New World Ovens
How do I set clock on the New World oven SGO 60
It has 6 buttons in a row - no symbols or text to indicate function
BADBOYJAY
  • 264 Answers
SOURCE: function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Posted on Jan 05, 2008
IB4G2008
  • 3587 Answers
SOURCE: Clock shows strange code, oven won't operate
that's an error code for something else that's not working..do you have the owners manual?
Posted on Mar 09, 2008
MARCLAVORIS
  • 110 Answers
SOURCE: Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Posted on Apr 03, 2008
e-Guru
  • 3917 Answers
SOURCE: Frigidaire es340 Electric Range -
Hi
Please check this links as per your query :-
http://www.repairclinic.com/Range-Stove-Oven-Troubleshooting#Itsstoppedcompletely_electric
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 15, 2010
FitzOriginal
  • 842 Answers
SOURCE: oven clock no display and
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Posted on Jul 06, 2011
F&p OB60SL11DEPX1 built in oven. Bought this as an off the floor demo. Just installed it. All the functions, clock etc work but elements not heating up. Troubleshooting says it might be in demo mode!!
It could also be a faulty circuit breaker. If one of them trips internally it may not trip the handle or indicate one is tripped. This situation allows only 120 volts to reach the oven instead of 220. That's why the clock functions but not the elements. To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
Oct 22, 2016 | Ovens
The lock symbol is showing but the door can open and no functions on the oven will work apart from the clock
This is the keypad lock (symbol looks like a padlock?). Find the button that has a padlock symbol near it, hold down for 3 seconds, should unlock your keypad. This should be described in your user manual if not indicated on the touchpad.
Aug 28, 2015 | Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
Jul 06, 2011 | New World Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Missing instructions on how to use and set
where can I get a user manual for the New world G60 built in gas oven please
Jun 04, 2010 | New World G60m Gas Single Oven
How do you set the clock and get it to stay on
press the clock button to set the time. Press the "up" button which looks like a triangle symbol or the "down" button whih looks like a triangle upside down symbol until the correct time is on the display , then hold in the clock button for 5 seconds for the time to be displayed.
Apr 15, 2010 | Whirlpool RBS275PD Electric Single Oven
WHIRLPOOL GY396LXPB00 MIGRATION CONTROL PROBLEM
press and hold at the same time child lock ( 2nd button in the row of buttons under the clock. and cancel ( bottom button far right ) hold until lock light blinks (10 -25 sec) hope it helps
Jun 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
99 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
