Question about HP Office Equipment & Supplies
<!-- from fixya rte -->Hp design jet t790 error code 2.0.10 - HP Office Equipment & Supplies
  • HP Master
  • 1,121 Answers
Wrong error code, Pl check once again
Posted on Dec 09, 2014
faxman789
  • 297 Answers
SOURCE: getting a system error 1180
System Error 1180: Capping Motor Error
Description:
Capping Motor over current is detected.
Corrective Action: Try the following:
When the ambient temperature is very low, the Pump Motor Tube becomes hard and the load on the Capping Motor is increased. Make sure that the Printer is in an environment where the temperature is not below -10oC or higher than +85oC.
The Capping Station has a Torque Limiter for up and down operation so that the Capping Station does not experience any over current. Apply grease on the shaft of the Capping Station Gear so that it helps with rotation.
Make sure that the Capping Station cables are connected correctly and are not damaged
If the Capping Motor cannot be rotated, replace the Capping Station
Replace the Main PCA if nothing above corrects your problem
Posted on Jan 15, 2009
puertobori
  • 7733 Answers
SOURCE: We have a HP Design Jet 500 We turned it on and
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
cyberware
  • 196 Answers
SOURCE: What is system error 0B0006
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Posted on Feb 12, 2011
seeker5211
  • 1089 Answers
SOURCE: I have an HP design
22:10 Ink Supply Station failure.
Get the Ink Supply Station replaced.
Get a tech to do the work. You will not want to do the work yourself.
Posted on May 06, 2011
SOURCE: Service Manual T790
hi.i have the code but i cant say that here.hp designjet t790 service menu code 09361002314 azad
Posted on Oct 15, 2012
Hp design jet t790 error 47.01
You'll be much happier with a Canon or Epson when you decide to replace this.
Apr 23, 2017 | HP Office Equipment & Supplies
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
May 15, 2015 | HP Designjet T790 44-In Postscript...
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Aug 13, 2014 | Office Equipment & Supplies
How to recovery Hp Designjet T790 24-in hard disk?
jeano: if you don't have the Recovery DVD, get with the Manufacturer of the hp Designjet, they will send it free (in warranty) with instructions. bigAl
Apr 19, 2014 | Misc - MFG CR650BBCB Hp Designjet T790...
Error se 36:01 hp designjet t790
If this error code was caused by a paper jam better could you tell what lead to this erro, unplug the power cable from the printer and clear the blockage. Open and remove the Clean out assembly from the printer and see if you have any particles left inside it. Plug in the power cable again and check if the Error Code has disappeared.
Nov 15, 2013 | Office Equipment & Supplies
Hp design-jet 450 edge sensor not working
You mean to say that line sensor not working, How you confirmed? Are you check the error codes?Align media & Data both led's are glowing?..If yes, clean it with solvent or replace line sensor which was mounted beside of carriage assembly.(see fig)
If error message is different, pl share it, for further solution.3_26_2013_10_32_17_am.jpg
Mar 25, 2013 | HP DesignJet Office Equipment & Supplies
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
Service Manual T790
Mar 17, 2012 | Office Equipment & Supplies
I have an HP design jet 70 showing error code 2210 any help would be appreciated.
May 05, 2011 | HP Designjet 70 InkJet Printer
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
66 people viewed this question
Seeker5211
Seeker5211
