Question about DeLonghi Heating & Cooling
Could you tell me the white cables placement on the home heater radiatior Delonghi 3107's double switch?
Hello, I need to replace the double switch on my Delonghi 3107 heater radiator (one of the switches is broken). Before removing the switch, there is a pair of 6 cables that need to be unplugged from the switch before removing it; the cables go on the upper, middle, and bottom part of the switch. On top goes two black cables, and either on the bottom part, or in the middle, go the other pair of white or black cables. I really cannot remember if the white ones go on the middle section of the switch or if they go on the lower part, could anyone help me? Thank you.
    Problem Solver:
  • 14 Answers
Those white cables are jump serial lines should go in the middle
Posted on Dec 01, 2014
  • Julio
    Julio Dec 01, 2014
    Thank you very much for your help
I don't know your particular unit, but typically multiple plugs on the same board have a slightly different configuration from each other making it impossible to install incorrectly. I would suggest closely inspecting the male ends one by one and compare them to the female receptacles and see if that holds true on your application.
Dec 01, 2014 | DeLonghi Heating & Cooling
I have model TYP 3107. I bought used without wheels. Can I but new wheels?
Unfortunately, the model number you listed does appear to be correct. However, if you can find the correct model number, you can possibly find the wheel assembly at the following link.
http://www.appliancefactoryparts.com/search/index.php
I hope this helps you and thanks for choosing FixYa.
Jul 26, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
The on/off toggle switch on the side of my model no. 3107 has fallen off. I would like to replace it.
I was able to fix mine - it was a failure of the pivot points, I drilled out where they'd been, put the switch back together, and inserted a brad (tiny nail) for a new pivot. Works great!
Nov 27, 2010 | DeLonghi Heating & Cooling
Have typ. 3107, oil leaking out, how do you replentich oli??
If it is leaking... you need to throw it out...they are factory sealed and the oil is not refillable or replaceable...
heatman101
Aug 25, 2010 | DeLonghi Heating & Cooling
Hi. I have a DeLonghi 3107 radiator-type heater, g...
Personally I would throw it away. those radiator type heaters were OIL filled when new ,not water filled
May 20, 2010 | Heating & Cooling
Hello, I have a Model # TR0715 that needs a power
yes a switch opens and closes the power take old one to hardware store or local electrical supplier
Jan 16, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Oil heater not working
Request a wiring diagram from DeLonghi
Jul 15, 2017 | DeLonghi 9707 Oil Filled Radiator Heater
Heating & Cooling Logo
113 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
