Error C6708 in bizhu 750
Error C6708
How do you fix code error 5102 on konca minolta bizhu c353
check the paper draws and registration assembly. or might have a burned out transport motor worse case main board
Jan 23, 2017 | Konica Minolta Minolta Bizhub C353 Copier
I have a konica minolta, bizhub 750 that is showing an error massage 'c2401. can someone help?
Thread Bizhub 750 error code 2401
Maybe the link above will help. I found it by a google search, and unfortunately I am not familiar with that model.
Apr 22, 2016 | Konica Minolta bizhub Office Equipment &...
What is c6708 code in bizhub 600
Causes:
AGC adjustment level abnormality.
• The light blocking cover at the read section and the lens cover are removed.
• The connector of the CCD board (CCDB) is disconnected.
• The power cable of the CCDB is unplugged.
• The IC protector of the CCDB converter board is cut off.
• The light volume of the exposure lamp is excessive.
• The exposure lamp does not light up.
Feb 22, 2016 | Office Equipment & Supplies
How to fix problem biz 750 code c6708
Exposure lamp that is the bright light under the big glass that come on when scanning, the code also is associated with the CCD that is the device that see's the image you wand to copy or scan again under the big glass to your right, has a lens on it. One or bot are bad.
Jun 25, 2014 | Konica Minolta bizhub 750
Biz hub 750 code c6708
check the the bright light under the big glass come on, raise the doc feeder press the start button does it come on, second deals with the CCD which is the black device under the big glass to you left, need to have tech look at it.
Feb 08, 2014 | Konica Minolta Office Equipment & Supplies
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
Sync Error with Pam Treo 750
I have this treo 750 now for 3 monnths.. now when i click on Windows it only shows no drop down or no options
Apr 30, 2008 | Palm Treo 750 Smartphone
46 people viewed this question
jasbo
jasbo
