Question about DeLonghi Heating & Cooling
Could you tell me the white cables placement on the home heater radiatior Delonghi 3107's double switch?
Hello, I need to replace the double switch on my Delonghi 3107 heater radiator (one of the switches is broken). Before removing the switch, there is a pair of 6 cables that need to be unplugged from the switch before removing it; the cables go on the upper, middle, and bottom part of the switch. On top goes two black cables, and either on the bottom part, or in the middle, go the other pair of white or black cables. I really cannot remember if the white ones go on the middle section of the switch or if they go on the lower part, could anyone help me? Thank you.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
I don't know your particular unit, but typically multiple plugs on the same board have a slightly different configuration from each other making it impossible to install incorrectly. I would suggest closely inspecting the male ends one by one and compare them to the female receptacles and see if that holds true on your application.
Posted on Dec 01, 2014
Testimonial: "Will do, thank you for your help!"
  • 33 Answers
SOURCE: DeLonghi 5108 Oil Filled Radiator no longer works?
The DeLonghi 5108 has no thermal fuse. There was a problem with the control panels and DeLonghi was to offer free repair. Details on http://www.cpsc.gov/cpscpub/prerel/prhtml91/91108.html
which includes a toll free number.
Posted on Jan 11, 2008
SOURCE: Farenheat baseboard heater F2544
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Posted on Oct 23, 2008
SOURCE: Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Posted on Oct 08, 2009
vertdriver
SOURCE: How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Posted on Dec 22, 2009
  • 149 Answers
SOURCE: Hello, I have a Model # TR0715 that needs a power
yes a switch opens and closes the power take old one to hardware store or local electrical supplier
Posted on Jan 16, 2010
I have model TYP 3107. I bought used without wheels. Can I but new wheels?
Unfortunately, the model number you listed does appear to be correct. However, if you can find the correct model number, you can possibly find the wheel assembly at the following link.
http://www.appliancefactoryparts.com/search/index.php
I hope this helps you and thanks for choosing FixYa.
Jul 26, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
The on/off toggle switch on the side of my model no. 3107 has fallen off. I would like to replace it.
I was able to fix mine - it was a failure of the pivot points, I drilled out where they'd been, put the switch back together, and inserted a brad (tiny nail) for a new pivot. Works great!
Nov 27, 2010 | DeLonghi Heating & Cooling
Have typ. 3107, oil leaking out, how do you replentich oli??
If it is leaking... you need to throw it out...they are factory sealed and the oil is not refillable or replaceable...
heatman101
Aug 25, 2010 | DeLonghi Heating & Cooling
Hi. I have a DeLonghi 3107 radiator-type heater, g...
Personally I would throw it away. those radiator type heaters were OIL filled when new ,not water filled
May 20, 2010 | Heating & Cooling
Jan 16, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Oil heater not working
Request a wiring diagram from DeLonghi
Jul 15, 2017 | DeLonghi 9707 Oil Filled Radiator Heater
Heating & Cooling Logo
80 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
