Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG friedge trips when plugged, how to resolve this?
Checked wires and plug, all seems okay.
    Problem Solver:
  • 10 Answers
If the compressor and ventilators ate running you have to charge gas on the unit. Check the accumulator if is not blocked of pure ice.
Posted on Dec 01, 2014
How to fix tripping LG friedge?
You didn't say what is tripping. If it's the circuit breaker could have several causes 1 too small for the unit. 2 It has been used as an on and off switch, this shortens the life of a breaker.3 the breaker is not making good contact in the panel and the terminals are burned.
Dec 01, 2014 | LG Heating & Cooling
How do you change the fuse in a window unit?
some uneit have a fuse in the electronic board, i would put a new electric plug first is it 220v or 110v go for the plug first
May 24, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
I have a 2003 Dodge Stratus and the power outlet quit working. Have checked the fuses they seem fine. Any suggestions?
If this is the cig lighter plug then check for power at the fuse, with key on accessories, using a test light or multimeter. Sometimes a fuse will appear okay but has blown in a hard to see area. If you have power there, then check earth contact at the plug or connection of positive wire onto rear of plug.
Aug 03, 2009 | 2003 Dodge Stratus
Kitchen Aid range Breaker always tripping ERROR F5:E3
The elements or a hot wire feeding the control switches has been bumped and is grounded. You can probably find it with a thorough visual inspection. Look very close at the wiring and look for something pinched or touching metal.
Jul 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Help. My LG electric dryer, DLE5977 is not working
Hello berkyiu2002,
I'd be happy to assist you but an you elaborate on what happened? I can only assume you checked the basics...such as the circuit breaker has not tripped to the receptacle your dryer is plugged in to.. and the cord from the dryer is plugged in to that receptacle properly.. otherwise, please tell me what happened and when it last worked...
Regards,
Rick
Nov 29, 2008 | LG DLE5977 Electric Dryer
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Sep 13, 2008 | Dehumidifiers
New LG Dishwasher Suddenly has no power
My LG dishwasher purchased in '06" began giving me IE errors,
so after talking with replacing the circuit board & the overflow switch it still didn't work.
I inspected the wire harness closer which os located behind the door and found the wires weere heated and frayed. Now I need to replace it but I feel that the problem will be resolved once I replace the main harness. There ar emany issues I read about nightmares with LG so I will not buy them again!!
Jan 02, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
50 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
