Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Is there a filter underneath the container which stores the dust and hovered materials I can see there is colth filter but there seems to be a filter missing two the underside of that like the one on
Pls advise
  • Official Brand Answer
  • 2,572 Answers
Hi Stephen, it's Jack at Dyson.
DC07 has two filters - a washable pre-filter, and a non-washable post-filter. Both are engineered to last the lifetime of the machine without replacement in normal use. The pre-filter should be washed at least once every 3-6 months using cold water without detergent, as shown in the video below:
The post-filter is housed in a compartment below the clear bin, and is not intended to be accessed by the user. It doesn't need maintenance, and shouldn't be washed.
If you'd like further advice on either filter, or if you feel your DC07 isn't working as well as it should be, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide assistance.
Posted on Dec 01, 2014
  • Dyson Master
  • 18,424 Answers
This video will explain
My Dc25 has suction but not when the container is fitted how can I fox this
You have a clog or restriction somewhere in the dust container or the vacuum. You will have to follow the airflow from the dust container to the brush bar to Determine where the clog or restriction is. There could be more than one.
Feb 08, 2015 | Dyson DC25 Animal Bagless Upright Vacuum
Under neath the filter at the base of cleaner should there another filter underneath the colth one
If you are referring to the filter at the base of the machine on the right hand side (standing in front of the machine with the clear cylinder directly in front of you), then, when you remove the filter housing you will see a filter with what looks like the spokes on a wheel. The cloth-type filter is permanently attached to this part. Behind that should be a round, thick, blue foam filter with a hole in the middle (like a doughnut).
I hope this answers your question.
Nov 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Dyson upright cylinder stuck wont release to empty unit
I have had this happen to me (DC14 Animal). This was my experience:
If you have recently had the motor filter (the "permanent" one under the dust container, right on top of the motor) out and have replaced it, it is important to make sure that the filter cover is down properly, otherwise the canister will not release.
I got the dust container off by pushing it downwards, quite hard before pressing the release button. You really will have to push straight down on it quite hard. Then investigate why the dust container is so high that it will not release.
Jul 30, 2014 | Dyson Vacuums
We inherited the shopvac 16 gallon. I bought the required filter (foam) but the dust blows back from the blow hole. Am I missing a part?
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Jun 23, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Filter seems clogged.
Its fully blocked, needs stripping down and cleaning.
Start with the brush roller compartment, clean in their and take the bucket off and clean all filters Get your contractor back and tell him to get it serviced.
The motor housing will need cleaning as well.
Aug 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Electrolux Pronto 2-in-1: Looking for a part
There is no replacement for the dust container in these units. You would have to get an entire handvac which costs more then a full unit.
Jan 02, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Filter
i wouldnt, it usually soaks the dirt into the filter, try using a shop vac with a dust brush attachment that is the easist and cleanist way to do it.
Sep 01, 2008 | Vacuums
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
http://dysonmanuals.llc.nu/
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Upper Filter gets clogged quickly
You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
Jun 10, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
102 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
