C602-33 after I clean it says comp on too long ? How to fix
    Top Expert:
  • Computers & ... Master
  • 23,236 Answers
What says it is on too long? There is no windows error log that does that.
Posted on Dec 01, 2014
Dewalt Aircompressor model 55168 type 2 is leaking on small hole under the adjustment knob how do you fix it from constantly leaking?
Assuming your talking about the regulater it is repairable. first remove from comp. disassemble bottom needle valve and seat by simply unscrewing round cap on bottom of reg. check to see if the valve is hanging up . normally due to air comp. oil blow by. clean lubracate and check for o ring or seat damage. remove 4 screws from top of reg. first loosen adjustment knob to release spring tention once you remove make sure diapham isnt torn or damaged clean lub. reassemble bottom valve push the needle down to make sure it releases and works properly. reassemble top diaphram spring adjustment and cap test if the through cleaning doesn't work and in my experiance it does 85 % of the time you can buy a rebuild kit for it. hope this helps it is a simple repair
Feb 24, 2013 | Dewalt Air Tools & Compressors
On the screen is only /attention / entering sleeping mode/no video input what is a problem?
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Apr 06, 2011 | Computers & Internet
I have teouble to start my comp i got one long tone and followed by three short tones , can you help me whats wrong to my comp. Mod : GA-686LX3
Remove RAM, clean slots by blowing air, fix RAM back and check whether it is properly seated.Check whether all the wires connected to the motherboard are fixed properly.
Sep 03, 2010 | Gigabyte 440LX (GA-686LX3) Motherboard
A 5 ton condensor 12 year old drawing about 33.3 amps it's tripping 40 AMP RATED BREAKER. i't cooling kind of o.k. when it works blowing a temp of about 58 degrees with 95 ambient.
33 amps sounds high, try amping out the compressor by itself then compare to nameplate FLA for it. Make sure the condenser (outdoor) coil is clean, between the fins too, and make sure your fan is running ok while comp is on. Sounds like the bearings in the compressor are giving you problems, A high amp draw on the comp will tell you that. If the comp bearings are bad, you should check your charge, make sure your filter, indoor coil and fan blades are clean, those being dirty can cause a situation where liquid refrigerant gets into the comp, causing big problems.. If you do find the comp bad, I suggest you get a new one lined up before you are stuck in a hot house.
Good Luck
Jun 12, 2009 | Goodman PHKJ048-1 Air Conditioner
Fan constantly running,have comp presario sr1420nx about 4 yrs
If blowing the dust did not help your only other options are replace the fan or replace the heat sink with a newer one that incorporates a quieter fan.
Jun 09, 2009 | HP Compaq Presario SR1420nx...
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
I spilled soda on my key board not a lot i cleaned it off and turned off the comp for a few hrs will my comp be ok
Yes, you would notice the problems immediately. The problems that would occur would be hardware short circuiting.
Feb 21, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion A805N
Try remove and clean the memory fixed back and switch on the system.
if not solve.
If the VGA is add-on remove it and clean and fixed back and switch on the system.
if this all not solve notify me for further instructions.
Jan 07, 2008 | HP Pavilion a805n (PS519AA) PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
