Question about LG Heating & Cooling
<!-- from fixya rte -->How to fix tripping LG friedge? - LG Heating & Cooling
    Master:
  • 602 Answers
You didn't say what is tripping. If it's the circuit breaker could have several causes 1 too small for the unit. 2 It has been used as an on and off switch, this shortens the life of a breaker.3 the breaker is not making good contact in the panel and the terminals are burned.
Posted on Dec 12, 2014
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
LG DICHWASHER TRIPPING POWER
I'd say either the motor is siezed or there is something in the drain impeller. The water is recycled a bit so if a fork or some such is in the impeller it would stop it from turning which would overheat the pump motor which would be potentially very bad. This sounds like a job big enough for a certified service call.
Jan 12, 2015 | LG LDF6810ST Stainless Steel Built-in...
LG friedge trips when plugged, how to resolve this?
If the compressor and ventilators ate running you have to charge gas on the unit. Check the accumulator if is not blocked of pure ice.
Dec 01, 2014 | LG LFX25960ST Stainless Steel French Door...
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
Sep 04, 2012 | LG DLG3788W Gas Dryer
I was de-icing my mini friedge freezer box and punctured it. I know you're not supposed to use sharp objects or obviously this will happen. How do i fix it?
sorry to be the bearer of bad news but the way to fix it is throw it out and buy a new one. to repair that coil that was puncutured and recharge the refrigerant would cost more than new one,plus its very likely possible water from the melting frost entered the tubing and has gotten into the compresser totally destroying it as well so add the cost of compresser and coil repair its way more than new one would be
A costly yet valuable lesson to never do that again
Jul 28, 2011 | Refrigerators
LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Apr 30, 2010 | LG WM2016C
KIC 223l fridge - what length time reqd to let gas settle?
if it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Jan 28, 2009 | Refrigerators
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
