MY PANASONIC WASHING MACHINE ID DEAD NO POWER INDICATION,NO DISPLAY AFTER PRESSING ON/OFF NO RESPONE,BUT WALL OUTLET POWER IS HEALTHY
PLEASE HELP
This is a modern machine and has a digital controller/display
so the low voltage supply circuit usually on the controller board has failed
usualy caused by water or a short or something come loose
check all connections
i feer youll perhaps need to replace the controller board
too be sure of a good lasting repair
this is what i would do then i would fix the older one and return to stock doing any firmware updates to it also
Posted on Dec 02, 2014
  • 1028 Answers
SOURCE: Hi, I have model wfw8400tw00
most likely machine control bd bad remove top control is on right front corner ckd all connections first but suspect control is bad
Posted on Dec 17, 2008
SOURCE: In the middle wash cycle, the washing machine just
Your posted comments were a big help... The problem was electrical. The lid switch was the problem. I ordered and replaced the switch and it works fine.
Thank you for your help.
Posted on Feb 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: No power to washing machine
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 713 Answers
SOURCE: drain pump and motor control board was replaced.
Hi just read your posting.Sorry to ask these questions but why did you replace the control module and pump?When you turn the power off then on at the wall does your machine light up the display and give a beep as well? Did you hear a popping sound when you tried to use the machine?Did you smell anything burning?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: my bosh washing machine not washing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Oct 01, 2010
Push button switch does not work
Sounds like a really dead machine. You have to start at the outlet, with something to see if it's working.
If the outlet is good, are any lights or indication of power on the machine working?
If no indication of power shows, a technician needs to open the machine to see what's wrong.
Nov 27, 2013 | Electrolux Washing Machines
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Drain pump and motor control board was replaced. Entered the load size and when to start the machine and the display lights went out. Unable to do anything with the display panel now. I have power at...
    Sep 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
    F 11 code
    F11 is an indication of a communications problem.
    Communications cannot be sent correctly between the machine control board and the motor control board.
    Here are some possible causes:
    • Loose wire connection at either the machine control board or motor control board.
    • Machine control board failure
    • Motor control board failure
    • Door lock
    • Motor
    Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
    In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
    1. Unplug or turn the circuit breaker off for 10-20 minutes.
    2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
    3. Press the Pause/Cancel/Stop button twice to clear the display.
    4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    Jun 17, 2010 | Kenmore HE2 Plus Front Load Washer
    No power up in washer
    I have the same problem with my GW52F, i have checked the power supply and it works fine with other appliances, any ideas?
    May 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
    I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
    Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
    2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
    3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
    Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
    Kenmore het3 washer just quit, no power.
    If power to the unit then most likely the machine control went bad and would need to be replaced. There are no fuses or reset buttons. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
    Nov 30, 2008 | Washing Machines
    Washing Machines Logo
    35 people viewed this question
    Top Washing Machines Experts
