Question about Cameras
I plug in my nikon coolpix s60 and it does nothing
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Posted on Dec 01, 2014
5 Suggested Answers
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Posted on Aug 19, 2008
  • 11967 Answers
SOURCE: Mac doesn't recognize my Nikon Coolpix
Use a cardreader to download your pictures. Download them to a folder you create on your desktop. From there, you can do anything you want with them.
Posted on Aug 13, 2009
  • 11967 Answers
SOURCE: Nothing on my nikon coolpix s220 indicates that
Do what the pros do...use a card reader.
Posted on Jan 23, 2010
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
Service manual NIKON Coolpix S710
Hello if you are looking for the service manual for nikon s710 you can download it cheap from the below link::
http://goo.gl/HDFe3
Thanks
Jul 18, 2011 | Nikon Coolpix S710 S570 S560 S550 S640...
Tip
Nikon CoolPix S60
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S60-Digital-Cameras-review-manual/id/22085bh432/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
on Jan 05, 2011 | Nikon COOLPIX S60 Digital Camera
I just need a battery charger for my NIKON COOLPIX S60
Here are few sites that sell the charger you need over the internet:
1) YLMart
2) SterlingTek
3) Amazon
4) Power Battery US
Good luck,
Pelu.
Apr 06, 2010 | Nikon COOLPIX S60 Digital Camera
When i hook my coolpix s60 to my ubs cord to my computer i dont have a folder to upload my pictures on my computer (nothing pops up)...what do i download to upload my pictures
What software are you using now? You can download the latest version of Nikon Transfer from http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
In addition to Nikon Transfer there are plenty of other photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
Mar 12, 2010 | Nikon COOLPIX S60 Digital Camera
My nikon s60 work on off takes pictures but when i
Is it the E18 error? Are pictures fines when you transfer them to the computer?
Jan 30, 2010 | Nikon COOLPIX S60 Digital Camera
Need a driver for Windows 2000for my Nikon Coolpix S60
download driver here:
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/4657
Nov 05, 2009 | Nikon COOLPIX S60 Digital Camera
Troubleshooting
Sir i have a nikon s60 the flash will not fire i have reset the camera tried everthing some body told me i had a 8 gb memory card it is a super talent card not the correct card any ideas thanks
Jun 10, 2009 | Nikon COOLPIX S60 Digital Camera
Lens will not open
Try pushing the lens gently inside then side to side. It should zoom right out when turned on. It happened to my S70 coz when my kids played with it dropped it.
May 23, 2009 | Nikon COOLPIX S60 Digital Camera
Nikon Coolpix S60 is the camera. The problem is
Put the memory card into the camera, then use the "Copy" command in the Playback menu.
Mar 08, 2009 | HP Photosmart M415 Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
