Question about Minolta Office Equipment & Supplies
How do in fix my minolta 420 replace fixing unit message
I replace new fusing unit
  • Minolta Master
  • 6,161 Answers
You have enter service mode, Hold down the Utility/Counter Button and power on the machine. Go to counters life fusing/fixing same thing unit.
Posted on Dec 06, 2014
5 Suggested Answers
  • 32 Answers
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
Posted on Aug 15, 2010
  • 57 Answers
SOURCE: how to reset fuser unit forkonica minolta bizhub
In tech mode :
System 1
Initialization
Counter Data fixing Unit
Start button
Shut off the copier ans switch on
Posted on Jun 23, 2011
  • 57 Answers
SOURCE: how to reset fuser unit message for konica minolta
In Tech mode :
System 1
Initialization
Counter data fixing unit
Start button
Power cycle the copier
SOURCE: how to reset fuser unit for konica minolta bizhub
whats the error cod c-d202 in bizhub c420?
Posted on Aug 21, 2013
How can i fix rror code c-2803 on b361
Sir/Mam,
You recently replace the drum and the developer??? if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN TCR/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the TCR is run. Or you will start all over again with new developer and a new drum.
Sep 20, 2016 | Konica Minolta BizHub 360 361 420 421 500...
Why the c-3461 error comes
Sir/Mam,
Press Utility/Counter, Details, "Stop 00 Stop 01", (Password if required 92729272)
After replacing a fusing unit or transfer belt unit, perform New Release to clear its life counter.
1. Select the key as follows.
[Counter] ? [Life] ? [New Release]
2. Open the front door.
3. Select a unit where New Release is made.
4. Press the Start key and perform New Release. Exit out
Apr 10, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
How do I fix error message C3452?
It is most likely your fusing unit. Part number 9J06 R706 00 .
If you have had any power surges recently, meaning lightning struck your building and something else was hit. It could be the main board. You need to put a surge protector on this machine either way.
Oct 03, 2014 | Konica Minolta Office Equipment & Supplies
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
What is error 3801 bishub 420?
Fuser temperature control abnormality.To reset Turn OFF the copier.Press and keep pressing the Utility key,turn ON and wait to message Trouble reset appaire on display.Release the Utility key turn OFF the copier,wait 1 minute and turn ON.If the error code persist repaire the fusing unit,check the thermistors on upper fuser riller.
Jul 12, 2014 | Konica Minolta Office Equipment & Supplies
How to clear change fixing unit error
replace the fixing unit or the fuser as some will call it
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
How to reset fuser unit forkonica minolta bizhub 420
In tech mode :
System 1
Initialization
Start button
Jun 22, 2011 | Konica Minolta Office Equipment & Supplies
How to reset fuser unit message for konica minolta 420
In Tech mode :
System 1
Initialization
Start button
How to reset fuser unit for konica minolta bizhub 420
In Tech mode :
System 1
Initialization
Start button
C5201 error konica minolta bizhub 420 i removed fuser unit after that coming like this error ple help me
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
Mar 15, 2010 | Konica Minolta Office Equipment & Supplies
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
