Question about Broderbund The Print Shop 20 Deluxe for PC
I get an error code 1321 when trying to uninstall printshop 2.0 I can't run it either
Disconnecting internet, turning off anti virus
  • 655 Answers
Try downloading ccleaner. www.ccleaner.com I their "tools" section, you should run the uninstaller for that program. It is a FREE downlaod and I have used it for years...
Good Luck...
Posted on Dec 29, 2014
2 Suggested Answers
SOURCE: I have printshop 15 which
You can use the Revo Uninstaller to completely uninstall the application.
Click here to download Revo Uninstaller
Posted on Feb 01, 2011
Catastrophic error 0x8000ffff in system restore in windows vista
Uninstall your anti-virus,run a disk cleanup and try again
Aug 23, 2017 | Acer Computers & Internet
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Will not allow me to install Reader 9.2 Error
try to completely UNINSTALL your adobe reader program. Then reinstall it. If the problem persists, uninstall the program again (Adobe reader) and delete the Adobe Reader folder in your Program Files folder. Then reinstall.
Nov 05, 2009 | Adobe Acrobat 7.0 for PC
Failed to calculate hash for 'c:\Program
Basically the McAfee self-test has failed - you either have a corrupted file or are infected by some form of malware or virus.
1) Download Avast!
2) Download Adaware
3) Download HiJackThis
If you do not have them
4) Disconnect from the Internet
5) Install all programmes in this order HiJackThis, Adaware, Avast! and Run each immediately after they have been installed
6) If you wish to continue running McAfee then uninstall it
7) Reboot computer
8) Install McAfee
9) As you should not have two Anti-Virus Programmes running uninstall Avast! - Although I believe Avast! to be a better product
10) Reboot Computer
11) Reconnect to Internet
That should be you go to go
If this helped you, then please help me and vote, thank you
Oct 10, 2009 | Microsoft Windows 98 for PC
I need free trial f anti virus
I would recommend AVG or COMODO. But, remove (uninstall) any existing anti-virus software, first. You cannot have 2 anti-virus software running on the same PC.
Jun 29, 2009 | Computers & Internet
Install my printshop22 deluxe on my computer
go to control panel then add and remove programs uninstall the origanal and then reinstall it should work ,if you have and anti virus program running shut it of and dicconnect form the internet there should be no problem
Mar 24, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Canon imageclass MF3240 and Vista - not working?
uninstall the printer and all of software. then down load the drivers and software and save them to your desktop. then disconnect your pc from the internet, disable your anti virus and fire wall, then run the install from your desk top. alot of anti virus software see's scanner drivers as virus like activity and will not allow them to be installed. all in one installs like this need to be done without anti virus software running. i think this will solve you problem ive solve it many times like this
Feb 01, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Downloading
Hi kja2 ,
2 anti-virus software can not co-exist on a computer system ; therefore you did the correct thing by uninstalling the old anti-virus first . However , there are lots of anti-viruses which do not get deleted (uninstalled) by going to Start > control panel > Add/Remove program. These anti-virus have to be removed by special "uninstallers" . I do not know which Anti-virus you have on your system , therefore I will provide you with the link of most common anti-virus uninstallers :
Symantec: http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2005033108162039
McAfee: http://ts.mcafeehelp.com/displayDoc.asp?docID=408302&categoryId=246&lastCategoryLog=1&HotT
Trend Micro: http://esupport.trendmicro.com/support/viewxml.do?ContentID=EN-1033129
once the antivirus is removed through the uninstaller , then try installaing the new anti-virus which was giving you "files corrupt" message ... it will then work fine.
Also , . I would like to suggest you a very good anti-virus which you can download free of cost from internet :
http://free.grisoft.com/ww.download?prd=afe
Goodluck :-)
Jun 05, 2008 | Microsoft Windows XP Professional With...
I have Norton Internet Security..the anti-virus problem
Download this program ( NORTON REMOVER ) and uninstall completlly...
Rebot you'r pc
Install it again
DONE
Nov 18, 2007 | Microsoft Office Outlook 2003 for PC
Broderbund The Print Shop 20 Deluxe for PC Logo
51 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
