Question about Dryers
Is it good for 220 v electricity, or only to 110 v ?
  • 3 Answers
Hi
does it allow you to switch from 110v to 220v ? if it does then you got to switch it according to the power supply from the plug point that you are going to plug it into. Do NOT switch it to 110v and plug it into a 220v plug point .
if it is only 110v and not switchable then you got to use the only 110v
Posted on Dec 01, 2014
Wire 110 to 220
If you have a 110 volt appliance, all switches , wiring and components are made especially to handle that voltage. If you feed 220 to 240 volts into it, most certainly the machine will be unsafe and likely fail in a very short time. Purchase a step down transformer to reduce your supply voltage to 110. Most good electrical parts stores should be able to supply this.
Jun 26, 2014 | Craftsman Air Tools & Compressors
How to hook up 110 from 220
basically 220 is two (2) 110 legs and a common/ground leg.
in theory you take one 110 leg and a common/ground and you have 110.
however, electricity is a strange bird - I would highly suggest you consult with an electrician on what you are attempting to do - and in what manner.
I would not feel good without an electrician or some other knowledgeable person advising you on this 'in person.'
Aug 05, 2011 | Heating & Cooling
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
How change to 220 dryer machine to 110
its a good idea, but you cant,
the elements are set up for heat through resistance
on 220 you actaly have 110 on both sides of the heater,
if you want a 110 dryer your gonna have to go with gas, or buy a dryer manufactured for 110 heat, but Ive been doing this for alot of years and I have oonly seen like 3 and I dont remember the manufacture
sorry i could help more
but you should be answered, it was a good question
Oct 19, 2009 | Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
The 220-110 volt saga
Not sure, maybe broiler and oven element on different circuits?
Aug 31, 2008 | GE Profile JTP56 Electric Double Oven
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Dryers Logo
63 people viewed this question
Top Dryers Experts
