Question about Coffee Makers & Espresso Machines
Is it good for 220 v electricity, or only to 220 v ?
  • 3,961 Answers
Check the rating plate on the appliance. This should tell you what is the voltage rating. and if it says to operate on 220V, then it should operate OK on a supply anywhere from 200-240V.
All domestic electricity supply can fluctuate by about 10 percent, and appliance makers know that.
Posted on Dec 01, 2014
I switched off the power prior to looking at this, i did not wire it. landlord replaced thermostat yesterday after the heating element had already been replaced2xs now, 0 hot. heater model 71-40sb
Is this a 220 VAC H/W Heater or a 120 VAC H/W Heater?
Note: Info provided here is for a 220VAC H/W Heater
Thermostat doesn't look like a new one, maybe it is used!
Check input power (voltage) on top two wires if this is a 220VAC H/W Heater ... then the input power from the C/B in the Electrical Panel should be 220 VAC. If 220 VAC power is not present on the top two wires ... you may have a bad C/B in Electrical panel. Make sure C/B is turned ON and if still no power on top two wires replace C/B. If 220 VAC is present on top two wires then press Red Reset Button very hard to make sure it is Reset. Then check for 220 VAC at the Thermostat ( bottom two terminals), if 220 VAC is present then check for 220 VAC on the Heating Element terminals (bottom of picture). If 220 VAC is present on the terminals of Heating Element then H/W Heater should be working otherwise Heating Element is Bad and replacement is necessary. Good Luck! Handy Henry
Feb 09, 2017 | Element Water Heaters
Lower element is not getting any voltage
First check that all connections are good. turn off power and take off the cover plates pull out the wires connected with wire nuts and check that they are not loose remove any electrical tape covering the nuts and turn power back on. with a meter check that you have 220 at the connections. if all is good at the incoming service check the upper element if power passes it in parallel check the exiting connections.if good there check the bottom power if you have 220 there either your element is bad or the thermostat. check the element by turning off power again and check the element with a continuity tester. if the element is good then your thermostat is probably defective try turning it up higher and see if you get 220 out of it.
May 04, 2015 | RELIANCE ELECTRIC WATER HEATER
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
The element has been replaced but when the previous one was removed, the mains electric was left on and fused the main oven light and fan
who in hades left the mains on?! do they have any brain cells between their ears!!? if it's 220-240 (if you're in Europe, prob. 220-240) a wonder you don't have a smoking corpse in your kitchen! us yanks use 220-240v for dryers and stoves, but have 2 120-110v breakers, usually, to shut off 220-240v appliances. sometimes 2 110-120v breakers locked together, so they are both shut off at the same time! seems as if something was connected incorrectly- and fried your fan and light! may need to replace fan & light, and, possibly wiring! unplug the dam thing first!!
good luck!!
Oct 19, 2009 | Neff U1863 Double circotherm super...
How change to 220 dryer machine to 110
its a good idea, but you cant,
the elements are set up for heat through resistance
on 220 you actaly have 110 on both sides of the heater,
if you want a 110 dryer your gonna have to go with gas, or buy a dryer manufactured for 110 heat, but Ive been doing this for alot of years and I have oonly seen like 3 and I dont remember the manufacture
sorry i could help more
but you should be answered, it was a good question
Oct 19, 2009 | Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
My heating elements for both bak and broil suddenly do not work.
Verify 220 volts of power to the oven. If 220 volts is present and all wires are in good shape, replace the electronic control.
Jul 05, 2009 | Dacor MCS130 Millennia Electric Single...
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
