My screen cracked in a circle on vizio 42". The picture was working until I pushed screen then it went black, still have sound with no picture, can it be fixed?
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
There is no repair; other than replacement, to a craked screen.
Electro help
Posted on Dec 01, 2014
SOURCE: help - 15 mth old 42" edtv "plasma" black screen" have power and sound
I had the same problem....wasnt the main board but the two smaller boards...vizio changed them and no problem since .....
Posted on Feb 19, 2008
  • 103 Answers
SOURCE: No picture but has sound
With all the listed sets,itis most likely the y-drive(sus) board.The only problem is that this board usually fails when the horz.buffer ic's fail,which is usually part of the plasma display.This was a semi-common problem with this set.The best bet is to find a new set,since the parts alone will exceed the cost of a new one.Pioneer or nec seem to be the most reliable that i have seen.
Posted on Mar 05, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: Vizio 42 Plasma Pop
My 42 Inch Vizio experienced the pop of death out-of warranty. I bought mine at Sears and they sent a technician over within a day or so. It turned out to be in the power supply and they shipped a board right out. Total including parts and labor was $280. Although no expensive TV should die after less than 2-years, Sears seems to be able to deal with repair in the home without drama.
Posted on Sep 30, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
I have a vizio plasma 42" hdmi 720p 1080i tv with
The panel part #'s will have to match exaclty, the Ysus board # will have to match as well.
Dec 30, 2012 | Televison & Video
My vizio plasma has sound black screen
Your Tv possibly have faulty y sustain board, just replace that board to fix the problem
Dec 03, 2012 | Vizio P2 42 in. HD-Ready Plasma Television
Can you fix this cracked screen problem on Vizio VW42LFHDTV10A? and no sound?
We used to say have a short service on the patio and buy a new set---damaged panel display unit is more than set cost (if it is even available)
Let it go---when damaged it can instantly damage other boards/parts in the set.
Run a car with no oil and see what happens........
Mar 20, 2012 | Vizio VW42LF 42 in. LCD HDTV
42" vizio vw42l - no picture or sound
If the backlights for the screen do come on and you also have 12v and 5v feed the main board then it does sound like the mainboard will need to be replaced.
Nov 28, 2009 | Vizio VW42LF 42 in. LCD HDTV
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
hey twinbrother, sounds like we have the exact same issue, i'll let you know if i figure anything out. sure seems like it blew a fuse or something?
Mar 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Jan 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
