Display panel shows 'original loaded' even when no document loaded
Display panel constantly shows 'original loaded' even when no document is loaded. I have tried to set it to 'Factory Defaults'
    Habit-Forming:
  • 91 Answers
In ADF ( automatic document feeder ) check if there is jammed paper or clean paper sensor it may dusty
Posted on Dec 01, 2014
  • 4 Answers
SOURCE: How can I load factory defaults??
I don't know about factory defaults but there is a Firmware UpDate v 2.4.0
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002800/dlf002854.html?reg=us&c=us&lang=en&prod=mfc640cw_all&type2=4&os=7&flang=4&dlid=dlf002854&dispforlist=1
give it a try ...hope this works kiddrock
Posted on Feb 14, 2009
  • 15 Answers
SOURCE: Lexmark x644e LCD Display Inverted(Upside Down)
You will likely need to replaced the LCD panel
Lexmark p/n: 40x0494
You can order it here at www.fastprinters.com
40x0494
Posted on Sep 29, 2009
Roop1980
  • 228 Answers
SOURCE: The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
Posted on Oct 01, 2009
l_j_duplessi
  • 29 Answers
SOURCE: Kyocera KM 3035 copier display panel says:
the switch in the finisher that get press by a pin that is setuated on the leftside of copier need to be adjusted or cleaded or replace use a small skrewdriver to activate the switch if it work you now to adjust it if not open and test it with a tester swicth the machine of remove the disconnect the finnesher from copier fi problem is gone the finnesher is the reson fi not it is the wireing to the engin board or engen board on copier fi problum is at finnesher it and the switch is working on finnesher the chek wireing to FN board if that is fine and the wireing to the copier is fine and the conector between copier and fn is fine it is the FN board
Posted on Aug 07, 2012
  • 18 Answers
SOURCE: HP PhotoSmart scans, copies, won't print. Computer indicates "open door" even though printer display does not.
try to uninstall and reinstall the program files see if that fixes it
Posted on Mar 12, 2014
When trying to send a fax a brother 1360 and after dialing the number rings but the document will not scan and displays 'telephone'.
The reason why your mahcine shows telephone because it can't recognize the document that you loaded in.
Try to remove the document from the feeder and make sure that your mach shows date & time. Load the document again in the feeder and the display should show enter fax # & start, that's the time you need to dial the fax # and hit the start key,
Hope this helps,
Mar 28, 2011 | Brother Fax-1360
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Keeps printing documents over and over - things from yesterday and last week even!
Try doing a soft reset to see if your can clear the printer's memory cache:
  1. Press MENU/ENTER.
  2. Simultaneously press then release the * button and the # button to enter the Developer’s menu.
  3. Press the < or > button until the message REINIT FFS appears on the second line of the control-panel display.
  4. Press MENU/ENTER.
  5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready.
  6. When the Ready message appears on the control-panel display, press CANCEL to exit the Developer’s menu.
Mar 16, 2010 | HP LaserJet 3015 All-In-One Printer
Display showing Remove orig from ADF
Remove original from auto document feeder... it thinks that there is a paper jam... check into that.
Jun 05, 2009 | Canon FAX L-120 Plain Paper Laser
Handset constantly display missed calls
you have to clear them. it will show missed call on all the ones you did not answer the call on.
Mar 09, 2009 | Panasonic KX-TG1033S Cordless Phone
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
59 people viewed this question
jasbo
jasbo
