Question about Casio Protrek Sports Twin Sensor SGW-300H-1AVDR SGW-300H-1A Mens Watch
How to set real altitude measure and time setting
3071PRG-1107.CASIO, TOUGH SOLER WITH TRIPPLE SENSOR,WOULD YOU LIKE TO GUIDE ME HOW CAN I SET MEAN SEA LEVEL AND TIME FOR DIFFRONT COUNTRIES,ALT & BAR TO SET IN MY WATCH
Noggin
  • 944 Answers
SOURCE: I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Posted on Mar 25, 2007
SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
Posted on Feb 11, 2008
SOURCE: setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Posted on Mar 09, 2008
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Posted on Mar 12, 2008
  • 13433 Answers
SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
Casio FX - 9860G SD have complex equations??
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Mar 16, 2012 | Casio Office Equipment & Supplies
Mar 16, 2012 | Casio FX-9750GPlus Calculator
How to set the time on a casio tough solar?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
May 24, 2011 | Casio Tough Solar Watch MTP1227
I can not set altitude on my TCM Winter sport Watch
Go to altitude view (ALTI) - may need to press 'Sensor' (top left) once, and then 'Mode' (bottom left) to display.
Press and hold Mode until display starts flashing. Keep pressing Mode until the setting you want to change is flashing, then use right-hand side buttons to change.
Press and hold Mode again to get out of the setting interface.
The different altitude settings which you can change between using the Start/stop (top right) button:
ZERO - for use when skiing or when you want to measure a relative change in altitude.
ALTI - Input known measurement above sea level
SEAP. - Current air pressure
F.DEF - Factory reset barometer to 1013.2hPa
Apr 06, 2011 | Sport & Outdoor - Others
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
I have a casio g-shock not work the Altitude Measurement
The riseman can be reset but also needs to be calibrated. Your instruction manual will walk you through calibrating your altimeter.
If you have misplaced your manual you can download a manual from Casio's website.
http://support.casio.com/manual.php?rgn=1&cid=002
Sep 16, 2009 | Casio GShock Riseman AltiTherm GW92001...
My Casio waveceptor tough solar watch will not pick up its signal
You may have wrong manual. Follow this link and find correct one:
Rate me, please.
Jul 28, 2009 | Casio Watches
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Casio Protrek Sports Twin Sensor SGW-300H-1AVDR SGW-300H-1A Mens Watch Logo
430 people viewed this question
Top Casio Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Casio Measuring Tool and Sensor Expert? Answer questions, earn points and help others
