Question about Harman Kardon Audio Players & Recorders
Distorion across the centre speaker of my Harman Kardon AV 1550
I'm just setup my Harman Kardon AV 1550 in the new home theater (it's been boxed for three years) and am noticing distortion across the center speaker. The audio is there but the best way to describe it would be 'furry'. I've used optical and coax connection into the unit, used two different speakers and different speaker wire. I guess it's in the amp but no idea what? Any thoughts? Don't wanna change it but possible cheaper to replace than fix. Cheers
    Habit-Forming:
  • 166 Answers
Have you tried another speaker on the centre channel ?
Posted on Dec 01, 2014
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 119 Answers
SOURCE: no dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Posted on Feb 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: Center Speaker Audio Very Distorted
Love your screen name.
You didn't say what, if anything, preceded the appearance of the problem. There might be a clue.
Can you describe the distortion? Is it excessively bassy? If so, is it happening on all sources?
I'm assuming this is a modern digital receiver that is capable of many soundfield simulations as well as native Dolby Digital, DTS, multi-channel. If so we can use a stereo source and through simulation redirect some of it to the center speaker.
Using one of your receiver's many multi-channel simulation modes, put in a CD or tune an FM station and use it to diagnose the problem during later steps.
If it's only a single source and that source uses individual analog channel RCA cables, swap in another one or temporarily move the Center Channel feed to one of the other channels to see if it's before the receiver (in the source).or inside the receiver.
For multiple sources:
Is your Center speaker defined properly as Large or Small in the receiver's setup menu?The size refers mostly to the bass-handling capacities of all your speakers rather than their physical size. Speakers designated as 'Small' will not be sent much in the way of bass because they can't handle it well. The LFE/subwoofer channel(s) will get all the bass that was intended for them instead.
If you have a Small speaker improperly defined as Large it may be getting bass that it can't handle and that might sound like distortion. Having a Large speaker defiend as Small would result in less bass than expected but otherwise 'clean' sound.
Check the speaker setup in the menu for excessive volume level relative to the others. There is usually a calibration procedure the receiver will use to help you adjust the subjective voume of each speaker using white noise or tones.
Hope this helps.
Posted on Apr 02, 2009
SOURCE: Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
Posted on May 13, 2009
SOURCE: Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Posted on Dec 23, 2009
Can i bluetooth pair my harman / kardon stand alone speaker with my ps3?
Harman Kardon AVR products and how to connect to devices
? 6:02
https://www.youtube.com/watch?v=3aPKTDlOlf0
Mar 11, 2010 - Uploaded by hyperconnected life
What I originally wanted was to have a bluetooth microphone that ... I have the av 1700 with harman Kardon ...
Esquire - Harman Kardon
www.harmankardon.com > Wireless > Portables
Harman Kardon
Rating: 4.7 - ‎16 reviews
Esquire is a Bluetooth®-enabled speaker with a built- in conference phone system ..... the sound will bounce and the bass gets a little nicer...but stand alone in the ... able toconnect it to my iPad Air as of yet; it will not recognize it on Bluetooth.Missing: ps3
[PDF]Owners Manual - Onyx Studio - Harman Kardon
br.harmankardon.com/...//harman-kardon/.../Owners%2...
Harman KardonBluetooth pairing mode automatically when it is turned on. NOTE: The speaker's Bluetooth device name is HK Onyx Studio and password is 0000. Introduction ...Missing: alone ‎ps3
Dec 16, 2015 | Audio Players & Recorders
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
No sound from my LG HD TV to my Harman Kardon receiver
Hi!.
i want to connect my akg t 912 headphone with Sony LCD. The audio output from setup box is attached with the Home theater and not directly to LCD TV. Suggest me the way to get the setup box audio output to AKG wireless headphone.
Jan 02, 2013 | Harman Kardon Audio Players & Recorders
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
Do you know if the harman/kardon avr125 reciever is 3d capable?thanks ..mrmitchfinance@yahoo.com
Actually Home theater sound, is 3D. (Three Dimentional) Your receiver, using surround speakers reproduces 3D sound.
i.e. It is Left to Right, and Front to Rear. Thus it's 3D. If your get a 3D TV, your sound will be just fine because it doesn't come from the set. The sound SOURCE is the DVD player, CD player or Cable Box. If you use digital audio outputs (optical cable or orange colored RCA cables) from these items connected into the Harmon-Kardon, your will get the full Home Theater sound. The Harmon Kardon does not have HDMI inputs however it will not need them for the purposes of sound. Your Receiver is a high quality unit. If you want the thrill of 3D TV, go ahead and get one. After you have set it up, if you then decide you want to go to 7.1 or some other SOUND upgrade, go ahead. One thing you should know, is that there is not a whole lot of audio quality improvement available after 5.1. Unless you have a very large living room. The real quality counts when choosing the speakers and sub woofer that go into the system, not the amount of speakers you have.
I have done a number of high end home theater installations and the experience of hearing the systems (mostly 5.1) has been a thrill for the owner.
I hope this helps you,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 125 Receiver
The sound does not come out of the speakers when I use my tv panasonic plasma, but when I use dvd,cd then sound comes out of the speakers, I have looked at the manual , help please, when it was set up this...
hi,
set tv in tv mode
go to audio setup then check the audio output settings. it should be in internal speaker setup,
then only u can hear the audio though ur tv. if it is in amplifier mode then the internal speaker will be off. check it first.
ok
Jan 11, 2011 | Harman Kardon HS 200 Theater System
Connection system
hi,
connect satelite speakers to the amplifier and connect signal cable (RC pin) to the woofer from amplifer ie subwoofer out from amp. ok na.
-kanny
kanny-sounds.blogspot.com
Dec 15, 2008 | JBL 5.1-Channel Home Theater Speaker...
Harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Dec 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
93 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
