Question about Sewing Machines
I got 4 in 1 mini sewing machine model no FHSM 201. It was fine in the beginning. Now I got looping problem in the lower side of fabric. I changed new needle also , but still problem exist. What shall I do?
  • Sewing Machines Master
  • 1,860 Answers
Try adjusting the top thread tension and see if the looping stops
Posted on Dec 01, 2014
Did it take you hours
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
SOURCE: looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
Posted on Nov 24, 2009
  • 17 Answers
SOURCE: Singer 2010 does not make the loop under the plate, to sew.
set up needle properly...
Posted on Dec 25, 2009
wfservices
  • 260 Answers
SOURCE: Feed dog doesn't move material through, huge
Check the tension of the feed foot. Some machines have an adjustable tension for the foot pressure. If this is not the case then re-check your thread tension setting. As well clean the bobbin area of loose threads and dirt. You can adjust the bobbin thread tension on the side of the bobbin holder(small screw). From the sounds of your dilemna the bobbin tension may be the culprit. The housing does come out with either 2 screws, or clips. Try that. Wayne
Posted on Mar 24, 2010
Testimonial: "Played with the bobbin tension and it's working great! Thanks:) "
SOURCE: Kenmore sewing machine #16227 needle thread making
It is most likely because you have it on a type of stitch but did not switch the didstance that you want the zig zag to be. Just change you stitch or your distance.
Posted on Feb 10, 2011
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
Mini sewing machine FHSM 201 stitches are coming loose.. How to fix this problem?? Tired adjusting the tension Spring but not happening .
Quick fix test:
Install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning so the upper thread will seat properly in the tension disk. Verify that the upper and bobbin threads are threaded properly.
If the problem continues, then it is probably something else, ie the tension adjustment is incorrectly set or malfunctioning, needle/hook timing may be off, etc.
Feb 12, 2016 | Sewing Machines
How do I set the tension on my JANOME 3434D serger?
Begin by setting all 4 dials on "3" which is the default setting on this model (often "5" on other machines). If a beginner, it would be best to thread the machine with four different colour threads according to the colours indicated on the tension dials (yellow, red, blue &green) so that it is easier to see how each thread responds as you adjust the dials. The two lower dials are for the loopers & must be adjusted until the upper & lower loops meet on the cut edge of the fabric - if below the edge: tighten the left dial & loosen the right dial (& visa-versa) just a fraction at a time. The two upper tension dials are for the needles: if too loose, loops form underneath the fabric below each needle, & if too tight the lower threads will show through to the upper side of your fabric where it is pierced by the needle. Good luck!
Jan 18, 2015 | Janome Sewing Machines
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
My singer sewing machine model # 774 will not produce a lower stich that is not all jumbled on the underside of the fabric. The upper stich is fine, it's the bobbin stich that comes out all jumbled. ...
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 08, 2011 | Sewing Machines
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Thread loops
Proper set of bobbins and tension set up vs. fabrics will sew you satified.Also incude regular maintenance cleaning of the feeds dogs with a brus,also the shuttle assembly need sometime to clean.Some threads and fabrics chips accumulates in the feed dogs and shuttles assembly.In setting up thread bobbins the thread should be clockwise direction as you pull out on slot coming out to the bobbins (as you shown in my inserted image manual).The loop thread should be propely in the sequence position same like in the image refer to it.If you use cotton/ polyester fabric in the begining of trial set tension dial to No.3 and stich to No. 8 to 12 any convenient to you Use needle No. 14 .Posible make a record if you are sewing different types of fabric mostly silk fabric is hard to sew adjusting to lower stich can posible sew satisfactory.
Mar 10, 2009 | Consew 206RB
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
