How can I find the potentiometer on my cd player as It picks up disks spins them but wont play them
Taken off the sides and back but I cannot identify the potentiometer at all even though I have folled instructions. Really need a video or picture of where it is and what it looks like.
    Scholar:
  • 82 Answers
As far as I know, there is no adjustment for the spinning of disks - the microcomputer determines the speed to spin the disk in order to read the pits properly. What I normally find is a dirty lens that can carefully cleaned with alcohol and a clean lint free cloth. Another problem I find is a build up of lint on the rods that the laser runs on that stops the laser head from going far enough along them to begin the reading of the pits. And one final problem I've seen that isn't fixable is that the very fine wires that suspend the laser focusing lens might be broken or have a real bug or dirt stuck so it won't go up and down properly read the pits on the disk.
Posted on Dec 01, 2014
Testimonial: "My question was.... where is the pontentiometer?"
  • David E. Colglazier Dec 01, 2014
    Sorry Tony but there is not a potentiometer for this function as that is handled by the microcomputer.
    Sergeant:
  • 268 Answers
Did you try a lens cleaner kit?
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
I have an Aiwa z650 3disc cd player,the disc spins a couple of times and then stops I'm told the potentiometer may need adjusting,I've taken the case of but can't find this thing
Not sure bout that ,,usally when it spins a few times and thats it,,motor wore out,,,put a disc in try as it stops spinning or right wen its fixon to start spinning given it a help spin,,i had that fix or getem goin,,,,also try tapping it ,,and hitting the side od the machine,,good luck,,
Dec 23, 2011 | Aiwa Audio Players & Recorders
The dvd player wont play dvd's it will play cd's
Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Aug 05, 2011 | Audio Players & Recorders
Cannot play dvd disk
Many probable reasons.
-You put dvd disk in a cd reader
-The Dvd disk is unreadable(full of scratch at the bottom)
-The Dvd reader is not identified by your computer.
1st identify what the reason is.
Then reply
Hope this helps. Thank you for using Fixya!
Apr 19, 2011 | Computers & Internet
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
 Grubhead
Grubhead
