I have a Philips 107e monitor... The monitor VGA connector is removed how it solder the cables with connector...
    Scholar:
  • 82 Answers
I don't understand your question exactly...is the connector you're referring to attached to the cable or the monitor? Or did it come un-soldered from the monitor PC board?
Posted on Dec 01, 2014
5 Suggested Answers
Franky_J
  • 15 Answers
SOURCE: Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Posted on Nov 25, 2008
SOURCE: VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Posted on Dec 24, 2008
SOURCE: cable color codes for samsung syncmaster 753s
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Posted on Feb 14, 2010
mace1mace
  • 1138 Answers
SOURCE: The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Posted on Jun 03, 2010
Vga connector
pls. check vga cable or get another cable there might problem with the cable.
Nov 08, 2013 | Philips 107E66 17" CRT Monitor
Philips monitor 107e 17" monitor
Hey there.
I have recently written a tip on this OSD lockout problem. I suggest you give it a read and let me know how it goes.
You can see my tip here:
http://www.fixya.com/support/r9424404-fix_osd_lockout_or_screen_display
Enjoy my tip.
Slasher_X
Aug 12, 2011 | Philips 107E56 17" CRT Monitor
During use often screen turn voilet white colour then after hitting the monitore some time it turn back tell me what is the problem
It may be related to DRY-Solder of the components on Main board of the CRT. So please call local monitor repairer and make it to solder the components properly without drysolder.
Jun 04, 2011 | Philips Magnavox 107E 17" CRT Monitor
My monitor e70fb is changing its color from normal to pink and pink to normal and the monitor menu is display automatically and changing the contents of it automatically.
I have seen this when there is a short in the cable (the cable is getting old) is the cable removable? the just get a new vga cable and all should be well. If not, then the only solution I know would be to replace the monitor or have it serviced. This monitor had a three year warranty but I am guessing you are beyond that. this monitor shipped in 2006, so it might be close. check your receipt and maybe you will be lucky. Hope this points you in the right direction.
Nov 18, 2010 | ViewSonic E70f 17" CRT Monitor
Jun 03, 2010 | Envision H170L Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
To down load driver file for CRT monitor phillips 107E
apparatnlly 107e is not the full model number http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?searchtxt=107E&ctn=107E&slg=ENG
why would you want to download a monitor driver? i have never seen a monitor require a driver to work.
the only thing a driver does is it should include the icm profile which supposidlly matches the color but every monitor is not the same so i would be suprised if it actually acuratlly matched the color.
Apr 24, 2009 | Philips Computers & Internet
CHANGEING MONITORS
Hi Laura and welcome to FixYa!
Yes, you should be able to change your monitor. You will notice that if you unplug your monitor's cable from the back of your computer, you will see an adapter that looks like the one below (called VGA).
I can't seem to find the specs on the new monitor you mentioned, but most new LCDs (flat screens) have DVI cables, which look like the picture below.
Don't worry, its an easy fix. Go down to your local electronic store and ask for a "VGA to DVI converter". It will look like the one in the picture below. Mine cost me about $8 USD.
I hope this helps. If you have any questions, do not hesitate to ask.
Happy Holidays,
-TJ
Dec 16, 2008 | Philips 170S4FB 17" LCD Monitor
Yellow Monitor
Its not something that anyone can do. you'll need to get a new cable and open the monitor to connect it on the inside. to get the vga connector cable you'll need to make the trip to a repair lab anyway, cause its not the generic kind with pins on both sides that you can get in any general computer store. Hope you work it out, and don't get yourself zapped please ;]
Apr 21, 2006 | SAMTRON 78DF 17" CRT Monitor
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
