Why do the flames keep going out - Heating & Cooling
If you are talking about a device with a pilot light, then it may be that the thermocouple has gone bad. The thermocouple is positioned right in the flame and provides an electrical signal that indicates when it is hot. If the thermocouple is not providing the correct voltage, then the rest of the system assumes the pilot light has gone out and shuts off the gas to avoid an explosive situation. The thermocouple itself is pretty inexpensive, so just swapping it for a new one is a reasonable thing to try.
Posted on Dec 01, 2014
  • mechaero Dec 01, 2014
RELAINCE 606 GAS WATER HEATER. WE RECENTLY HAD THE BASEMENT FLOOD DUE TO ALL THE RAIN. WE NOW HAVE NO HOT WATER, I AM SURE DUE TO THE FLOODING, BUT CANT GET THE PILOT LIGHT RELIT! HELP
If keeping the thermocouple bypass pressed keeps the gas flowing to the pilot but the flame goes out when it is released in spite of keeping the flame going the customary amount of time, then either the flame isn't powerful enough to reach and heat the thermocouple bulb, the pilot flame or the bulb is out of alignment or the thermocouple is faulty.
If the flame is weak it indicates a blockage in the jet or the supply pipe.
Sep 08, 2017 | The Kitchen Appliances - Others
Oven flame keeps going on and off
Does it reach the temperature you dialed in?
Then the thermostat is doing its work correct.
Mar 13, 2015 | Heating & Cooling
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
Oct 24, 2014 | Mr. Heater Natural Gas Garage Heater -...
I can"t keep my pilot light going.
I am assuming this is a patio heater. I have extensive experience with gas appliances. The most common problem with pilot light issues is the thermocouple it is a probe that is directly over the flame , it senses the flame and allows gas to flow, if it senses no flame the gas valve closes. Patio heaters are also quite finicky, sometimes a simple adjustment of the thermocouple will do the trick. Also thorough cleaning of the orifice is necessary at least 1 x a year.
Dec 12, 2011 | Pool & Spa
I can't keep the flow of gas coming from the tank to the burner going. The red "switch" won't stay up to keep the gas flowing. I can push it up and gas flows but when I let go - it pops back down cutting...
No. You are probably having a thermal safety switch failure. It measures the heat from the flame, and when its hot enough, it tells the gas valve to stay open. It's a safety feature to turn off the gas if the flame blows out, keeps things from going boom. Can't find a parts diagram to verify part numbers, or a manual to be certain. Typically, the red switch is to be held up til the flame is going, after lighting the flame, then released once flame is lit, 5-10 seconds is usually enough.
Dec 21, 2017 | Brinkmann 815-3786-0 Turkey Fryer
Gas dryer flame keeps going out, clean lint sceeen...
normally it is a flaim sensior or moor often the gas coils www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
I HAVE A NORDYNE E2EB 015H
Sounds like the flame sensor is dirty or bad. This is a metal rod that sits on the flame telling the controls that the burners is lite and it is okay to keep the gas valve open. If there is no flame it tells the control no flame shuts the gas valve off to keep excess gas from building up in the furnace. It could also be a faulty limit switch which tells the control the furnace is to hot so shuts the furnace down till it cools off. This is easy to check with an ohm meter with the furnace off check for continuity through the switch(usually a round disc looking thing with two wires going to it) if it ohms out then it is okay then run the furnace and after it shuts off check the switch to see if it ohms out if not then you have found the problem if it is okay could be the flame sensor try to clean it with a lit grit sand paper or emry cloth works good.
Jan 13, 2010 | Heating & Cooling
The oilot lite keep going out
Check to see if the pilot lite is going past the pin- (flame sensor) if not then your flame is too low , Clean the pilot oriffice or use air and blow out the system for dust.
Dec 08, 2009 | Desa International Heating & Cooling
Furnace keeps turning on and off
Okay, what is going on. is the system lighting or not. If it is just sparking then you need to just the gas value. But if the system lites and then only have a flame for about five sec. then shuts back off, then your flame sensor is dirty. Take a wire brush and clean the flame sensor. The flame sensor is right there with the burns because a flame has to hit it for the gas to stay running. Just take a wire bush and clean it..... let me know
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
Flame going out!
Take the flame sensor out and clean with fine sand paper or emory cloth
Dec 09, 2008 | Cozy (W352E) Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
