2430dl Konica Minolta will not print COLOR test pages. It will print the configuration page which is black toner. I may get a FALSE media jam error fuser. The fuser is NEW. Sensor on top is operating properly. I can see the color test page left on the transfer roller. Along with suggestions for a fix.. Does anyone have a flow chart to check for errors?
1. Remove side cover
2. Remove fan and housing
3. Remove solenoid4. Remove all traces of prior "pad" from solenoid swing arm
5. Replace pad with resilient silicone rubber pad approx. 1/16 x 3/8 circle. Pad must go on swinging arm not on tab
6. Reattach solenoid7. Adjust spacing to gear using tab
8. Close cover and go.
Or replace solenoid with pn: 9321 2400 21
The following symptoms are generally caused by a failed solenoid within the machine:
• Prints further down on the page than normal
• Paper Size Mismatch errors
• Transfer Roller jams
• Color quality issues where the color remains on the transfer belt instead of printing on the page
Description:
Printing 3 inches too far down the page; Paper Size Mismatch errors; Color Quality problems
Solution:
CAUSE: Failed registration roller solenoid (SL2).
Note: Under most circumstances it is recommended that the customer (end user) have a technician service the machine or replace the printer (if under warranty). However when dealing with a customer who is technically inclined and who would like to attempt
replacement of the part, the attached procedure can be provided.
SOLUTION: Replace SL2 (p/n 9321 2400 21).
Notes:
1. To order replacement parts, contact the Konica Minolta Supply Line at 800-972-6705.
If the end user (customer) would like to order and replace the part(s), it will be at their own risk if the installation causes additional issues.
Posted on Dec 01, 2014
  • 189 Answers
If you do not get an answer, you might try the company's Support site at:
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm
2 Suggested Answers
  • 6 Answers
SOURCE: Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Posted on Apr 27, 2010
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Magicolor 2430dl print processing error
Verify the IP adress in your computer and to copier,print one configuration page.
Feb 10, 2013 | Konica Minolta magicolor 2430 DL Laser...
Constant media jam
You didn't remove the toner cap. This is put into the toner to keep the black dust in the toner during shipment and handling. This is a strip with a pull tab on it. It should have a green pull tab. Pull it off and reinstall. It should work now.
Jul 08, 2009 | Office Equipment & Supplies
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
False media tray jam
clean take up roller, chack that the printer is trying to take the paper and lifts paper up.
Nov 09, 2008 | Minolta 2430DL Color Laser Printer
Minolta 2430DL Jams on the first Page of the Job and then Works Fine....
They are the stripper fingers and can sometimes pop out of position because of build up, you may want to try to clean these and check this specific finger against the other ones to make sure it is seated exactly like the others are...they are spring loaded so be careful when you back them away from the heatroll to clean them, they can be a real joy to put back in without the proper tools...
May 11, 2008 | Minolta 2430DL Color Laser Printer
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
81 people viewed this question
jasbo
jasbo
