Question about Toshiba 46XV640U 46-inch Hdmi Lcd Tv 16 9 Widescreen 1920 X 1080
My toshiba 46xv640u goes through the initial setup every time after turning it off and turning it on later.
I updated the firmware. No change. Every time I turn off TV I have to set it up again before I can watch anything. Has anyone else seen this?
    Scholar:
  • 82 Answers
Most newer LCD, LED, or Plasma models "flash" the setup into non-volatile memory devices so this is not normal. If you are requested to "save" the configuration and don't or don't know how, maybe this would happen. Even power outages should not cause what you are seeing unless the configuration is somehow not be retained when the power is removed or by chance you are using a power strip to turn it off when it needs constant power to retain the settings.
Posted on Dec 01, 2014
  • Tony McCollum
    Tony McCollum Dec 02, 2014
    I am familiar with saving the settings. I have been building my own computers since 1990. I save the settings then turn off the tv with the remote. I start it up again and wham, I have to go thru the initial setup every time. The set didn't do this when I purchased the tv. It started later.
  • David E. Colglazier Dec 04, 2014
    OK. Have you opened it up to look at the capacitors on the boards, particularly the power supply and the main computer board? It sounds to me like the flashing Power supply isn't working. If you see bulging caps, then I'd replace them but make sure you get low ESR ones. Lately, most of my own electronics are failing because of bad electrolytic caps.
4 Suggested Answers
  • 15 Answers
SOURCE: goes on and off on and off permantly
your backlight is going out.. get it replaced
Posted on Feb 01, 2009
budmrtn
  • 11361 Answers
SOURCE: II have a 46" Toshiba HD LCD TV and I believe the
Do you get lines on other input beside the HDMI? Component inputs, Composite input?
We need to narrow down the problem first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Posted on Jan 12, 2011
lovejoy91
  • 691 Answers
SOURCE: 50HPX95. Need Firmware\r\nHad a failed video
Notice (Read Prior to Beginning the Software Upgrade)
The following events may interrupt the upgrade process and result in an inoperative unit.
1) DO NOT unplug the Power Cord during the software update procedure
2) Avoid loss or interruption of power during the software update procedure
3) DO NOT Press the power button on the unit during the software update procedure
In the event of software upgrade failure please contact TOSHIBA Customer Service at 1-800-631-3811
Posted on Feb 11, 2011
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
Can I watch netflex movies on my Toshiba 46xv640u tv?
I just downloaded the manual from Toshiba and did a search for Netflix and nothing came up. When I googled your model I saw other people complaining that the TV didn't come with Netflix built in. You can download the manual here: 46xv640u om pdf
Jan 28, 2015 | Toshiba 46XV640U 46 in TV
32av502u toshiba stuck on initial setup language menu
Sounds like corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen shots illustrations.
Dec 14, 2014 | Toshiba Televison & Video
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
Why haven't you found solutions for the posts above???
Hello joe_east,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Firmware update froze my mp3
mine froze on that too but I just reset it and it turned on fine the next time. also does it connect to the pc. if it does you can reinstall the firmware through easy rip
Dec 29, 2008 | RCA M4208 MP3 Player
Changes get ignored after initial setup
It sounds like something I did (years back :-)) - entering the setup in the Router with a wireless conection, - THAT will go wrong, - use a wire when you access your Routher for changes.
/Teis
Helpfull? Vote!
Nov 23, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Initial setup wont work
you need to have the phone's firmware reflash so take it to a mobile service center and have that done.
Nov 16, 2007 | Motorola Mobility L6 Cellular Phone
My time doesnt change at daylight savings time
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Nov 04, 2007 | Motorola Mobility RAZR V3
Toshiba 46XV640U 46-inch Hdmi Lcd Tv 16 9 Widescreen 1920 X 1080 Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
