Question about Health & Beauty
How do I get. Schematic of the controller for Homedics SRM-700?
I have opened the controller and found the parts that were affected by it having been plugged into the wrong power supply but was unable the decipher the value of the capacitor that needs replacing and the on board fuse.
  • 4 Answers
SOURCE: Low voltage power supply fuses blown
Theres two jumper wires around the convergence ic's that supply the +/-32 volts to them.I found a cold solder joint on one of them.This causes the fuses to blow.Their close to the edge where the two boards meet.
Posted on Jan 25, 2007
projdoc
  • 2237 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
freetek
  • 5568 Answers
SOURCE: No power when plugged in. On off button stays dark, nothing works
Everyone has problems with SMPSs; mine started in 1971 when IBM was first using them; they were literally blowing up and throwing molten copper several feet.
Anyhow, if you have the benefit of a capacitance meter with DF function, check the main filter caps all of the smaller caps. The quality and durability of electrolytics is bad and getting worse and once one of these fails anywhere in a feedback path, the supply will not start. HF is hell on electrolytics.
The (ferrite) transformer in a switcher measures very low on the Ohms scale; depending on power handling and service frequency, primary <<100 Ohms, secondary from 0.? - 10 Ohms between taps, because they operate at higher frequencies. The 50 volts from the diode bridge is way too low; you probably have failed 100-200 uFd. electrolytics right close to them although this is fairly rare since they are only working with 120 Hz. From a 120 VAC line, you should have ~ 160-170 DC volts at no load if the caps are still working as they should and you have no notable resistance between the AC and the diodes.
Well-designed switchers are wonderfully efficient and very reliable if the maker didn't cheat on component quality. I've repaired literally thousands as a sideline in a now retired business and after studying them and adding a ceramic cap.or two and better quality electrolytics, they will run for decades. At one time, I had standard repair prices on ~ 70 different models.
My guarantee was 'lifetime' and that was limited only because I retired.
Posted on Aug 20, 2009
Testimonial: "Thanks fo the tip and taking your time to answer! Great insight! "
SOURCE: mlt070a power supply (polaroid 373b)
Mine are 100ufd 450volt 105C capacitors.
Hope this helps,
Mark
Posted on Sep 15, 2009
budmrtn
  • 11361 Answers
SOURCE: Vizio SV470XVT1A has no backlight
The 24vdc is turn on by the signal from the main logic board, it is not always on, the standby 5vdc is always on. So yes it can be the power supply board is bad, but just to besure we need to find out if it is getting the turn on signal from the main board first.
You can have 24vdc at the inverter board and it will not light up the CCFL until it gets the signal from the main logic board to turn the lamps on (this is the STANDBY condition, the TV is on but the screen in not lit up util it see the video signal).
Send me good clean and clear pictures of the power supply board, budmrtn@aol.com, connectors of the Power supply, bottom side of the board, then I may be able to tell you which pin is a control input pin. Most people will just throwing parts in and hope that they one of the parts will fix the problem. Used Power supply module for this TV is over $100. http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=delta+DPS-379AP&um=1&ie=UTF-8&ei=USsxTKn3J6TonQfFlJGEBA&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+SV470XVT+
Posted on Jul 05, 2010
Testimonial: "Bud helped me fix my TV! It was only 1 1/2 years old. I was looking at a repair bill close to $300 - $500 and I fixed it with a $60 board! Thanks!!!"
Problem is I get know low frequency from amp. I took it apart and found a schematic for the board online. I than ohmed out l11 the 33uh coil and it is reading 10k. I have never seen a uh coil read more...
You don't need to replace it, just unsolder the pins and you will find one disconnected, just solder it back and you're done, let me know if i can help more.
Oct 08, 2013 | Mackie SRM-450 System
The gas ducted heater wont turn off and is pushing cold air through the ducts. What should I do?
If you have checked the thermostat or control to make sure the fan setting is on "auto" and not on "On" or "Continuous" or something similar, then either the thermostat/control is bad and sending the wrong signal to the heater or the heater is not accepting the control because the relay/switch in the heater is stuck in the "on" position.
If you have the schematic for the thermostat/control then you can figure out how to simulate the control signal that would go to the heater and switch between "on" and "off" to see if that affects the operation of the fan. If you can simulate the switching and the fan turns off then the problem is in the thermostat/control. If the fan continues running then to problem is in the heater.
If you have determined the problem is in the heater and you have a schematic for that unit, then you can check the opening and closing of the switch that controls power to the fan to determine which component is not functioning.
Once you have found the malfunctioning unit, replace it or the assembly.
Aug 11, 2011 | Heating & Cooling
Where can I found the main fuse in a grey Mackie SRM 450 ?
The fuse is actually on the inside. You will need to remove the amplifier from the back of the unit. Remove all the screws and pry open the unit. The fuse will be on the inside.
Dan
Dec 14, 2010 | Mackie SRM-450 System
Mackie srm 350 tweeter is dead cannot find any UK parts servicesa that will provide either a new diaphragm/coil ot even the whole tweeter
I found that Stan at Surrey amps was able to supply a tweeter for a srm 350. But you need to let him have the full part number on the tweeter as it seems they have changed the design on the tweeter at one point ( or more ) in the manufacture.
phone (0)208 8730927
www.surreyamps.co.uk
regards Peter
Mar 16, 2010 | Bob Mackie SRM350 Main / Stereo Speaker
Lost eyelets Echo SRM-220ES strimmer
Hi these machines are made by allpower most parts you can obtain from your local echo dealer.
Sep 08, 2009 | Garden
Need parts for HoMedics BMAT-2 Bubble Spa
I'm missing the hose and now desperatly want to use Homedics BMat bubble Spa which is now currenlty not in stock. Can you sell the hose to me. 4189kv4r6yl._ss400_.jpg
Feb 25, 2009 | Home
Ilectrical problem
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Jan 01, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Health & Beauty Logo
70 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
