Question about GE Stove / Oven / RanMain Top Assembly White - WB62T10268
I have an electric stovetop and did a self cleaning it would not unlock so i turned off breaker and was able to unlock when i did the baking element was so brittle that it snapped and now all the burn
I have an electric stovetop and did a self cleaning it would not unlock so i turned off breaker and was able to unlock when i did the baking element was so brittle that it snapped and now all the burners will not work but the on light is on can you help
  • mark stein
    mark stein Dec 01, 2014
    also i noticed nothing is working except surface unit light and clock when i turned on broiler it did not heat my question also if the baking element broken(physically) would that stop all heating items to stop working?
    Problem Solver:
  • 9 Answers
Ok,... First, and foremost, stop using the self clean. It takes the temperature up to 900 deg F, and creates all sorts of other problems with the lock motor and the walls and the bake/broil elements. Use a Low odor Easy-off spray cleaner to clean your oven from now-on, please.
Now, the bake element needs to be replaced. If you have the model number (found on the body of the Range behind the lower drawer, if you pull it out) I can look-up the manufacturer's suggested part to be replaced. You may also need to replace the broil element, but that usually is the last element to burn-out as most people don't use the broil function of an oven.
You will have to pull the range away from the wall, and unplug it before you attempt to replace any parts. No need to have 240 VAC/30 Amps running through your body. There are several black 1/4" screws that secure the back panel on the oven section to the body (about 6 to 8) and they will have to be removed to pull and replace the wires on the oven bake and/or broil elements. You will also have to go to the oven door (on the front of the range) open it, and remove the two 1/4" screws that secure each element to the body before you can change-out the element(s). The most popular bake elements for GE Ovens are part #WB44K10005 and/or WB44T10010, but there are other Bake elements. Will need the model of your Range to ID the correct element and the cost.
Now as for the rest of the burners on the stovetop not working, they are usually independent from the oven functions, which are wired into the controller in the center of the range control console, but there are a couple of GE models that wired the stove burners into the oven timer/controller. If this is the case, then you may also need to replace the oven timer/controller.
If the stove elements are independent and are only wired to the Infinite switches that control the front left, rear left, front right, rear right burners, than the problem is either with the actual radiant heat burner elements or the infinite switches that independently control each burner. I would still need a model number for the Range to help you more with this.
Hope this is of some help.
Dave
Posted on Dec 01, 2014
Testimonial: "thanks dave the model number is jbp21gv2wh all the burners were working before so if you could let me know what you think i need to do i would appreciate it. someone else suggested i replace oven but i am not in a financial position to do that as things are very tight. Please help and thank you again."
  • David Dunne Dec 01, 2014
    The Bake element is part #WB44X5082 and they are about $37. If you also have to replace the broil element, it is Part#WB44X185 also aout $38. The more expensive part may be replacing the Temp Probe Part #WB23X5340 at about $93. The model you gave me shows coil stove elements, and not radient heat elements. Is that correct?
    If replacing the bake element doesn't get you back to working, then the main control will need to be replaced, as well. That is part#WB27X10215, and they are about $163, which I'm hoping you don't have to replace. Piecemeal repairs on this range may be as costly to repair as it might be to replace with a used range. It appears that the Main Oven Control has only the timer and the oven functions connected to it. The burners are independent, and are controlled by each Infinite switch for each burner, so now you have to look at each burner and each infinite switch to determine if one of the switches (which are wired in-series to the other switches) may be burned-out. Those Infinite switches are Part#WB21X5243 for both the 6" and the 8" burners. They cost about $31 each.
    Scholar:
  • 77 Answers
When you use the "Self Cleaning" feature on an oven, normally you will have to set the timer on the stove to determine how long it will stay on... typically around an hour. The locking feature is there to prevent you from opening it up because of the extreme temperatures that occur inside to oven during the Self-Cleaning procedure. The temperatures can possibly get up to 900 degrees or so. By not having the timer set at the desirable time, you in effect, crystalized the heating element causing it to be brittle.
I can't tell for sure without seeing, but I would suggest checking to the timer to make sure it is not still calling for the elements to be hot.
Testimonial: "how can i do that? check the timer im sorry if i sound but never dealt with this before.Any help would be appreciated"
  • Edward Hurst Dec 04, 2014
    The timer for the self cleaning feature is the same timer used to set for baking in the oven. Set the timer to stay on for approximately an hour and select "Clean". At the endof the time you set on the baking timer the oven will shut off and unlock when it cools down.
    Genius:
  • 1,056 Answers
Go and purchase a new stove, you've ruined the one you have. The reason you couldn't unlock it is because it was going through it's cool off cycle which includes heating it to lower temperatures during the cool down so that the element doesn't become brittle.
By turning off the breaker so you could unlock it defeated the way it's designed to work.
Sorry there isn't better news but it is all listed in the owners manual on how to run the self clean feature.
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
Had foolishly tried to remove baking element w/ oven turned off but still plugged in / breakers still on (all to make cleaning easier-ha!) unscrewed element beleiving it was modular like stovetop elements....
Some times s**t happens. The most likely situation is the wire connections that connect the heater have burnt off, or simply just become disconnected.
the normal repair or replacement to the lower heater element would be to disconnect the wires from the heating element by sliding the wire off of the spade connector. Some times they are connected by a screw and nut terminal. Next to remove the screws from inside the oven, and then pull the element out from the back wall. I can see how you could easily interpret that they would slide out like many stove top elements.
In your situation confirm that power is off.
Remove back panel and check terminal' connections to the heating element. repair.
Model ra520w3 HOTPOINT ELECTRIC RANGE Parts
maxresdefault-es3dyrcoa4nhevk3e5ork442-3-5.jpg Hope this helps?
Jun 21, 2017 | Hotpoint RA520 Electric Kitchen Range
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
GE Stove / Oven / RanMain Top Assembly White - WB62T10268 Logo
120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
