Where can I get Circuit board wiring for SRM- 700?
Plugged into wrong power adapter and blew up a capacitor and the protection fuse. Need to know the value of the capacitor and fuse.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 374 Answers
Both the Capacitor and fuse will have there rating right on them.
If you don't know that you might want to take it to a professional for repair, as soldering them in can be very tricky.
Posted on Dec 01, 2014
  • 12 Answers
SOURCE: no power at all
I am having the same promblem I think does your light flash on and off on power light, mine does I am going to trouble shoot the board on monday at my company I work for I am a tech at a company that repairs other lcds this big and bigger but not for vizio so if i find anything I will let you know if you want?
Posted on Oct 28, 2007
SOURCE: Sceptre power supply short circuit
I have the same problem. TV was JUST out of warranty. Sceptre part number is X37SV-Naga and the cost - $285.00 plus $20 shipping. Non-refundable, no returnable.
The TV is of course going to de-solder the board within a year again, so either a good heat sing on both thermistors is in order OR a law suit against Sceptre is in order for putting us a risk of fire.
Posted on Jul 09, 2008
localwonder
  • 6784 Answers
SOURCE: power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Posted on Mar 11, 2009
rulds2008
  • 3866 Answers
SOURCE: need to learn to take capacitors off the circuit board
Very carefully as we discussed in our expert forums this takes skill and it takes the right equipment as you can burn the thrid layer board and you will be without a TV. First you need a 40 watt iron, 60/40 rson core solder/you need wicking wire/ heat sink and a whole lot of experience. check this website www.badcaps.com even know he works on motherboards for computers this guy gives you tips I would follow them and heed to them if I where you!! Good luck with your repair!
Posted on May 25, 2009
  • 65 Answers
SOURCE: No power
If its after a lightning storm, it really could be anything. Your mainboard could quite possibly be shot. In fact almost anything in the TV could be damaged by a big surge. It could even be that your backlights went out from the surge too.
Does your power LED come on? What is it connected to? Directly to the power board or is it connected to the mainboard? If you have current through all the circuit boards, you may have a burnt tuner or chip on the mainboard.
Might not be worth fixing depending on the size/model. If its a big LCD, you could probably get a good deal on a working one of the same size with a broken LCD panel (~$100). Then you can just replace the broken LCD panel with yours and you have a fixed TV.
Posted on Aug 15, 2009
50" sanyo plasma wont turn on
Never replace a fuse, without checking for any short circuit in the board. Also never use a fuse higher than the rated one. These are safety devices that are meant to 'commit suicide' to protect others! You can try changing the capacitor. But my assumption is that the regulator section of the power supply has become defective and there is high voltage present there. This is a case to be handled by a qualified service technician.
Aug 04, 2012 | Sanyo Televison & Video
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
My aprilaire 700 isn't coming on (no water flow). The front part of the unit has fallen off the furnace twice (held on by plastic nubs/slots...) and blew the furnace fuse/ and circuit breaker probably...
Check for voltaged at the solenoid valve. This will either be a 24 volt or 110 volt solenoid valve. Confirm power into the unit 110 volts. If you have power into the unit and no voltaged at the solenoid valve on a call for humidification at the humidistat than the circuit board or the step down transfgormer has failed.. If you do have voltage at the solenid valve than the valve has failed.
Jan 26, 2011 | Aprilaire 700 Humidifier
If the power source was wired wrong and a "fuse blew" is that fuse on the circuit board and would I need to replace the entire circuit board?
The "fuse" that you have mentioned, is the Electrical Panel suppling voltage to your appliances, Chances are very Good That the Circuit Board has been Damaged, make sure your supply voltage is Correct,at the Dryer, and try the Dryer again.
May 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
1.6A250V fuse blows on V3500 power circuit board
Your DVD combo use a Switch Mode Power supply.
If you want to give it a bash here is a good guide that explains how they work and how to trouble shoot. http://www.repairfaq.org/sam/smpsfaq.htm
but ...
in 95% of the cases it is a shorted switchmode power transistor and other semiconductors, open fusable resistors, other bad parts. Note: actual cause of failure may be power surge/brownout/lightning strikes, random failure, or primary side electrolytic capacitor(s) with greatly reduced capacity or entirely open - test them before powering up the repaired unit.
Mar 01, 2010 | Samsung DVD-V3500 DVD Player/VCR
Sabrent ECS-U35K Hard Drive Enclosure AC Adapter repair
I would sure enjoy helping you figure your problem. I've taken Electronic courses in the Navy and in college, so this shouldn't be too hard.
As far as the capacitor goes, manufacturers make several different products from the same PCB layout, just some don't have all the components. Once I see where the capacitor should be I can tell you if its necessary or not.
For the fuse, it sounds like there is a short somewhere further in the circuitry. Rather surprised it blew right off the bat, but people and machine alike can make mistakes when building things. I fixed a laptop power supply where they didn't even solder the source resistor for the switcher.
Upload your pictures, and we shall we what we can do with it!
Nov 06, 2009 | Sabrent ECS-U35K USB 2.0 External Drive...
HP LCD Monitor w1907 Blowing fuse - no display
1. Visual inspection of the board, wires, etc. for short (expect you have already done this)
2. Start at the source. Need a meter to test voltage coming into the system (is it really 110VAC?)
3. Then the obvious, which is not so obvious or you would have fixed it by now. Need a meter to test components. Test switch. Maybe the power swtich is shorted!? Test all other components one at a time. Including all the wires. Do any of them feel stiff or look like the insulation might have melted a bit? Might need to remove wires to isolate components to test.
4. Since the power switch is not part of the problem then it is before the switch. When it was working, did anything run while the power was off? yellow LED? fan? Components like power diodes, bridges and rectifiers are typically blown by now also.
5. A filter capacitor, usually large, when shorted internally, can be the problem. Only test for short. Must remove one lead, watch polarity.
6. You can only blow so many fuses before the real problem, which the fuse is protecting, will appear...usually a disasterous end. I blew up a power supply to a washing machine after the third fuse. It fried the whole board with a very loud pop, bright flash and fragments of shrapnel flying everywhere. Please be careful!
Troubleshooters rules:
1. When you can't find the problem you are looking in the wrong place. Look somewhere else. Suspect everything, even the smallest detail is often the real problem. Like, what have you ruled out? Did you already assume the switch was good, the wire from the wall was good, the outlet was good, the power was good?
2. When you don't know what else to do, do something. Deliberately break something to see what will happen. (This is not a rule that I would use in this case but might serve you well in troubleshooting other problems in the future.)
Nov 28, 2008 | HP Pavilion F1703 17" LCD Monitor
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
No Power
There are fuses to protect from internal shorts, but not overvoltages. Fuses are soldered onto the circuit boards and not user replaceable. Sorry, but it needs to go to a shop - most independent shops could do the work for less than $120. Check the Fixya home page for shops.
Dec 19, 2006 | Samsung VP-L700U Camcorder
Televison & Video Logo
Top Televison & Video Experts
